Howdy everyone.
Not exactly new to SAU or the Nissan scene but after attending a SAU meet I figure I should introduce myself.
Current car list: (All were manual)
2010 Nissan 370Z - Tuned - Red with big body kit.
1995 R33 GTST beginner drift missile (onto third drift event) - Maroon - Regular mods - Power fc, turbo back, suspected high flow turbo, turbosmart street, front mount.
1994 R33 GTST - Midnight Purple - Stock minus a front mount.
Previously owned in the past two years:
2000 R34 GTT Sedan - tuned by DVS - 240kw - HKS turbo, exhaust, front mount, Eboost 2, GTR widebody kit - blaaaaaack - Adaptronic ECU.
2001 R34 GTT Coupe - 210kw - Nistuned - rims - exhaust - boost tee- - cleanest 34 I've ever seen.
1994 R33 GTST utter nugget spec - was skidded like no tomorrow - where I had a lot of my beginner skyline experience. Made 10psi and was fun for a while.
Owed a few Supras and XR6Ts but I'm a Nissan boy now it seems.
Feel free to ask questions
Edited by R34GTTBoi
Clarification
  • Like 1
https://www.sau.com.au/forums/topic/476319-hello-from-wollongong/
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
