RB25 build Piston dome volume
It's not going to affect how the car revs.  It's just not.
This is where the argument begun.
It will and its power and temps and the fuel you use.
All of wich you know but had to say the above instead of acuratley showing me how the balance of pressure is the same at different volumes vs C/R to enable the pistons accelleration to not change.
As i said how fast can the motor be spun by hand?
... lower the compression to suit and its faster..or raise the power to suit and its faster.
Thanks for a detailed reply but im not arguing wich is better as its my personal prefference for me and yours for you.
Would be lovely to run e85 cept its not viable cost wise for on road high k use yet.
Still wrong.  For every extra bit of compression working against the piston on the compression stroke, you have more power than that working against another piston on the power stroke.
What did i say wrong exactly?
"That more pressure will slow the compression stroke and cause more heat"
I did state i wasnt talking power stroke. because then power comes to play and volume is more effective for power.
The power vs resistance factor is now at play.
Wich then all comes down to air flow and fueling.
You cant take your turbo off and increase the C/R to make up for it unless you had superman fuel.
Do you see what im saying yet?
What is wrong is the allusion to ....
Because it is not relevant.  Just because the higher CR makes it harder for you to spin it by hand, it does not mean that the piston motion will be made slowed when the motor is running and having to work to compress to a higher ratio.  That is because the compression is being powered by power that results from the extra compression in other cylinders, and there is more of that than is required to to drive the compression event.  You can't just take part of the engine cycle out of context of the other parts, say something about it is true (when it is true only in isolation, but not true when put back into context) and then go on to draw conclusions about how the motor will run.
Your close but still not getting it.
If we add the cycle it works in favour of boost and low C/R according to fuel type.
You cant just say that basic physics doesnt exist...just because it can be hard to understand the exacts.
The explosive force of the extra air is mor than that of compressed with the fuels we use. And the motor has less resistance.
19 hours ago, Slap said:
inevitably robs you of rpm speed in higer rpm as the engine has to work harder where if its lower comp it puts more of the work on the turbo allowing the piston to move quicker as extra compression is pre done as boost.
This is where the nonsense is.  The engine will rev according to how much power it is making vs the load applied to it.  If you are still maintaining that higher compression will make the engine rev more slowly, then we still have a problem.
Wow , all I can say is calculators don't build engines for manufacturers or race teams .
There are some very simplistic ideas being promoted here based on guestimations being pushed as fact .
All I can say is that very few engine are ever anything like 100% volumetrically efficient and trying to add a bar of pressure to a compression ratio is hmm - maybe optimistic . Way too many factors shoot that one down in a screaming heap .
My take is that detonation is a factor of heat and pressure , whatever starts an unplanned combustion event .
With static compression ratios , many things have run very high ratios but it is hard to argue that it slows down the way an engine revs . If you don't think so go search for some data on compression pressures vs combustion pressures .
Fact . What higher static compression ratios do for you is increase the dynamic or actual compression ratio at less than full throttle . ANY restriction in an inlet tract will limit how much air a cylinder can inhale and if it aint full when the valves are ALL closed good luck getting the measured or "static" compression ratio .
Then you can throw in hot cams that open inlets earlier and close exhausts later , and generally increase the overlap valve timing , and you start loosing trapping efficiency . The less there is to compress means you get a lower dynamic or effective CR . Hot cams are designed to allow an engine to rev higher , to make more power at higher revs .
Don't ever lose sight of the fact that all you have to charge an NA engines cylinders is atmospheric pressure - period . Real word an engine CANNOT suck air in , all it can do is create an area of lower than atmospheric pressure into which the greater 1 bar at sea level can push itself into .
Edited by discopotato03
  • Like 2
Lol. No but it isnt as good at it as boost.
With boost and our fuels we are limited by materials to certain C/R. And it is easier to achieve a speedy motor by sacrificing C/R instead of boost on a boosted motor.
2 minutes ago, Slap said:
Whats the first mod you do?
Up Boost!
Not C/R!
Yuh, because a bleeder is 11ty times easier than new pistons.  If I was building my Neo right now, I would be putting in higher comp pistons and you could not convince me to do otherwise.
Slap, this makes no sense. your posts are a mix of sensible helpful statements, confusing bits, and complete nonsense.
This for example.
3 hours ago, Slap said:
Also back to piston speed...i should clarify i dont mean rpm or max velocity and enertia. I mean piston acceleration speed during compression stroke wich would be different from bottom to top depending on pressure.
if the rpm is the same how on earth can the piston accelerate or decelerate differently with a different compression ratio? the factors deciding piston speed are RPM, stroke, rod length. not compression. not possible.
I'll handle this one Ben.  The answer is compressible conrods.
  • Like 1
  • Haha 2
Rpm acceleration ben. Not all cars hit 8k the same speed.
The faster the piston can accelerate the quiker it can get to set redline.
I know im confusing and i dont mean to be but sometimes i feel like i have to defend myself before i can clarify and end up confused where your at only to go there and bring it back home in an evolving argument for you to see what im on about.
You are confusing rotating and reciprocating mass.
nevertheless the speed at which an engine can increase in revs when it matters, ie accelerating a car, is really dependent on how powerful the engine is, (keeping gear ratio, car weight the same)
 Share
    • Indeed. Mitsuoka always did their magic on various Nissan models, but because the Nouera was going to be in the medium sized sedan class, they decided not to try and modify the 2004 P12 Nissan Primera because it looked too modern combined with the 1940's styling. It would contrast way too much so they went with the more suitable CL7 Accord... 😆
    • It's also funny when an Australian company is boasting how their warehousing is USA/Europe...
    • Hi People, has anyone come up with a way of getting non-driven wheel speed on a R32 Gts/gtst? from what i've seen the RWD R32 didn't look to come with ABS, if they did i can't find a rwd ABS front knuckle anywhere. is it a case of putting a S14/R33 front knuckle on and then modifying the ASB ring to suit a ECU input frequency limit? or have people managed to get a hall sensor onto the back of the hub and pick up the wheel studs?   i've searched but there isn't anything that I could find.
    • I was thinking about a hoist, the ceiling is very high, but half the garage has a half-height loft for storage and I dont think I'll even be able to jack the X5 up under it as it almost hits me in my 6'5" elevated head when i walk in there. And, yeah nah, maybe if I can convince Bec to let me get another car she'd be open to having as many as we can fit (cough @Duncan) but until that time you better steer clear! 🤣
    • For the sake of cost comparison, I’m currently embarking on putting a new 5 speed into my R33. I imported a new RB25DET gearbox from Japan, which was about AU$3.3k delivered to my door. It was a very slow process (~2 months) and I got extremely lucky with the exchange rate. The twin plate clutch I bought was about AU$1.8k. I've also had to buy all the additional parts required to convert the gearbox from a pull type clutch to a push type clutch. Total cost is about AU$5.5k, so GTSBoy is pretty close to the money.
