Hey guys. Been scouting these forms for months since I got my car last year. I'm in Alberta Canada but this seems to be the best forum for info.
Anyhow, I have a. 1989 r32 gtst with the rb20det, fmic, rb25 turbo, walbro 255, blitz intake and bov delete. It will not idle when warm. The car will stall coming to red lights after the rpm drop almost everytime. I have a brand new tps sensor in the car and I still get code 43 (tps code). So I'm wondering is this my issue? Does anyone have any idea what the voltage is supposed to be going into the tps? I have 5v at the 3 wire plug and 12v at the tps sensor it self. I set the tps to. 0.48 where it should be and still nothing. I watched the voltage go up smoothly with the throttle all the way to wot (car off, ignition on) it reads 4.08v.
My iicv will not help adjusting my idle either..
Also while I'm revving the car. I'll hold and maintain idle at 3k or 4k whatever I tried it at it sounds like a misfire Is also happening. I have brand new plugs in the car so I'm certain it's not that. It boosted fine last summer with no hesitation or missing, (haven't been able to drive it since because of winter here).
What do you all think it is? Clearly an issue at the tps or something.
Thank you all for the help on this, I hope to have this solved rather quick. I do plan to swap some Toyota echo coil packs in very shortly too, if anyone has some info on wiring that would be appreciated too!
https://www.sau.com.au/forums/topic/476326-help-rb20det-tps-issue-wont-idle/
RB20s do not use the analog output from the TPS for the ECU.  They really only use the closed position switch for the idle position.  The potentiometer on them is for the TCU.  The idle switch should be set so that it changes state just as you start moving the throttle away from closed.  If you bend over the idling engine and you manually move the throttle bellcrank, at the very very first movement of it, the ECU should double pulse the injectors.  If you hear that at that point in the rotation, it is set correctly.  The trick is to set it too high, so you can tell that it is doing it, then adjust it down from there.
You MUST have the IACV working, otherwise it will stall coming to a halt.  Take it off, dismantle it and clean it with solvent.
OK so you don't feel like this is a wiring issue? I mean the tps is brand new and as far as I know setting it to 0.48 is all it should need to be done. I did clean my iacv but it won't adjust idle. I'll screw it either way and doesn't affect anything. I unplugged the tps while I did it.
No, you didn't listen to what I said.  RB20s are not RB25s.  The RB25 uses the analog output of its TPS (That's the potentiometer) for setting the idle point.  And the correct voltage setting for that is ~0.45v.  The RB20 DOES NOT use the potentiometer of the TPS for any function.  The pot is only for the transmission computer.  The RB20 uses the TPS's switch.  A digital switch.  On, off.  There is no 0.45 volts associated with that.  It is a simple click decision.  If you look closely at the TPS you will note that there are two connectors.  One for the ECU and one for the TCU.  In a manual car, the TCU one is not even really connected to anything.
As to whether there is a wiring problem with your IACV....there could be, but that is impossible to internet diagnose.  Dirty/seized up is always far more likely than a wiring problem unless someone clumsy has been buggering around with it.
Have you reset the ecu since putting in the new sensor?
To make sure its not the old code.
What happened to the old one, did it just die?
As gts boy said it might not be switching correctly.
How long has it been doing it?
Throttle body could possibly need a clean.
What got changed before it started this behaviour?
OK sorry didn't understand. Now I got it. So what you are saying is I should be able to adjust it forward till it idles ok then test?
I believe it is an old code but I don't know how to reset the ecu. I removed my neg battery cable and let it sit for a minute but didn't help. It has been doing this since I owned my car. About a year. One thing I haven't done is clean the throttle body. Maybe that's next
You can look it up specific or just wait for my buddy here to correct me.
Negative terminal off - Ignition on - press and hold brake for aprox 3-5 mins. Done.
Turn off key - put terminal on.
The ecu retains some power so by pressing the brake it tries to light the signals and drains the ecu.
Sounds simple. I'll give it a shot and then pull the codes after work today. Thank you!
  • Like 1
So did some diagnosing. Everything is checking out perfect. We had a scan tool to monitor everything and the tps is working, iacv working, the only thing I'm unsure of is the O2 sensor. Also I'm going to coil pack convert the car this weekend so that should solve any misfire I have I believe. But the idle hunt is still there. Now I got it to the point it will idle very well, but when I rev it a couple times the car will then drop the idle to 500 or less and struggle to stay alive.
[emoji849][emoji51][emoji3166][emoji856]
I have had to much negative feed back when i assist with things like this not that all the feed back is bad
. Hopefully someone will chime in b4 the temptation to hypothesis becomes to much!
Ahh i remember this... and i quote gts boy here as a flash back.
"Gents,
When Slap is asking about closed loop, he's talking about closed loop fuelling.  I suspect when Johnny Dose is talking about closed loop (in above posts) he's talking about closed loop idle speed control.  So, talking at cross purposes.
As has been posted before;
At idle (ie, TPS closed, ~0.45v) the ECU is definitely in closed loop idle speed control.
At idle, provided the O2 sensor is warm enough, the ECU will be in closed loop mixture control.  But this often fails and the ECU will just revert to the idle fuelling map.
At idle, the ECU does not change timing based on O2 feedback.
At idle, the ECU adds AND subtracts timing from the base 15° according to its needs for idle speed control, but is aiming to run 15° and control speed with IACV wherever possible.".
"Gents,
15 degrees is the proper timing for the rb20? I heard was 20 degrees? I'm going to retime the car this weekend as well after my coil pack conversion is done. So basically the O2 sensor would have no bearing effect on the idle of my car? I'm horrible when it comes to electrical.. So excuse me if I'm understanding things wrong here.
Thank you for the help
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
    • Righto,  enough of ADHD Anonymous! 🤣🤣 Rear end is completely stripped out apart from coil overs that will take 5 minutes.  Fingers crossed it doesn't look like that for too long!   Cleaning up some bits as I go so they can go straight back on. It amazes me how good stuff looks just with a good hard scrub! That will be it for a couple of weeks. I've got ot a bit of surgery Friday that will put me out of action for a few weeks. Hopefully the motivation is still there when I'm ready to get back into it!
    • The povo spec CA18S one, yeah. All turbos had 16x6.5 5 stud and 4pot brakes.
