Have read a few instances of people reporting the Nissan OEM timing bearing stud, and bolt, having broken which would be catastrophic to the engine whilst running....and you know I don't use the word catastrophic lightly, it's too much trouble to type to be thrown around willy-nilly.
Have seen this listing here for an unofficial ARP timing bearing stud and bolt set
https://www.boostfactory.ca/products/arp-timing-tensioner-stud-and-nut-for-rb20-rb25-rb26-rb30?variant=21433604505684
but haven't seen a listing for it anywhere else at all. It seems like a good idea to me to use a hi qual fastener like ARP for these bearings especially if running stiffer valve springs, tougher more rigid timing belt etc - what do y'all reckon, overkill or good idea?
https://www.sau.com.au/forums/topic/476332-arp-timing-studs-for-rb-engines/
I reckon that's overkill, and crazy money. The Nissan stud works, so long as it hasn't been over tightened in its life, so replacing with a new stock one torqued properly makes me comfortable.(uusing stock valve springs)
  • Like 1
  • Thanks 1
Agreed its fkn expensive especially when you see the shipping cos to Aus on that listing. I haven't seen anyone else list that kit, tho i imagine is nothing special, just a question of finding the right part no for those sizes?
Every time I’ve seen one break it’s been the bolt on the idler. I was unfortunate enough to have it happen on my first skyline in 2002, gave me a good reason to get rid of the rb20 and fit an rb25 though ?
  • 3 years later...
    • Ah. OK. I take it back. I hadn't looked closely at the R33/4 arms and presumed that GKTech did as GKTech do everywhere else, which is to use sphericals there. The poly bushings are made to be 100% interchangeable, should use the standard bolt just fine. Every other bush in every other place in pretty much every other car, does.
    • @silviaz Ok cool, so much easier with a video. I can see why this video would be confusing for new players.   It is obvious that this entire bonnet is going to be resprayed, have a look in the background around 2:05, you can see a bunch of bare metal on the left side of the bonnet.  It's not an issue for the primer being laid down on the non-prepped clear on the bonnet. It will be sanded off at a later stage.  This might not be obvious to new players, but working on bare metal and factory paint in this instance, the factory paint is like a mountain and the bare metal is a huge valley. The bonnet needs to be levelled flat before it receives it's final stage of colour and clear coat. During this levelling process, the primer that is landing on the clear that you are worried about will be removed.  Also, this guy is out of control. Zero PPE while spraying, maybe he is a good example overall about what not to do lol.
    • Ok I FINALLY found a video lol. This took way longer than it should have as I could have sworn I saw multiple videos like this. I kept finding the completely opposite (the correct way of doing this). I wouldn't be surprised if I f**ked this up somehow.  I just realised where I've been getting confused and even with other things I work on. I haven't been doing things the regular way instead I'm going a roundabout way of doing things, like putting epoxy primer first then filler for example instead of putting just filler then primer on top of that, then wondering what happens if I get that primer on the clear coat that I haven't sanded yet. This was a bit of an epiphany 😂  But anyways, here this video. Time stamp, 2:56, some of the primer lands on the paint unscuffed above. You can see from the reflection it looks shiny.
    • It does, this part circled in red. I assume the OEM bolt might not work well with the poly bushing because the dimensions may be different?
    • The J arm doesn't have bushes either. Assuming that by "J arm" you mean the part of the upright that runs down from the upper arm's outer bushes to the top of the hub. That has a kingpin style bearing in it. If you meant the lower control arm, it has 1 bush, at its inner end. If you have PU in there, that is superior to Nismo rubber. If you meant the caster/tension rod - it has 1x bush at the front end, and again PU is superior to Nismo rubber. But as I said above, I would definitely get the GKTech arms for that, as sphericals slay all other options there.
