well i've had a intermintint missfire in my car for quite awhile now and nearly coming to the point of not knowing what to check next, its also become quite hard to determine which cylinder it is. Diagnosing had become rather a big pain and am asking for help!!
so far i've, not all realating to fixing miss but could help....
changed engine loom wiring
changed CPU (currently got auto one, and manual car)
changed CAS
had injectors professionally cleaned and tested
changed AFM
replaced O2 sensor
cleaned ACC valve
checked cooler piping for leaks
done compression test with 10psi difference at the most
replaced coolant temp sensor
re wired coolant temp sensor
next thing i'm probally going to replace is the coil packs with some spitfire ones, but is there anything else that ive missed out on checking??????
https://www.sau.com.au/forums/topic/47634-missfiring-problems/
You did not say you changed the plugs but I guess that was a given? :Oops:
I know when I last had fitted iridium plugs and got MD to dyno my car he had to change back to platinums to get rid of misfiring. Even gave me back my $30 each investment :rofl:
My 33 started misfiring after i changed from coppers to platinums (still a 0.8 gap) and ran more boost and timing with the powerfc. I dont think the standard coil packs have much kick left in mine so im replacing them with spitfire's next week hopefully. I'll let you know how it goes. Oh, and as a temporary fix im using coppers gapped to 0.7, seems to have eliminated the misfire.
-rb25
yeah forgot to mention, i have replaced the spark plugs a few times now. i've tried platinums, iridiums, and now currently using coppers, gapped to 0.7 i think.
i'll probally try swaping the ignitor soon with a mate. coil packs are gonna be changed no matter what as they have those little cracks on nearly all of them at the top, as mentioned in another thread that i've read awhile ago.
Try this thread: http://www.skylinesaustralia.com/forums/sh...ead.php?t=32356
It has been the solution for many including myself.
If you talking about an RB25DET, then they are notorious for isfiring above 4500 RPM on higher than standard boost.
- a SAFC or PFC with mixtures leaned out to 12:1 will GREATLY help.
- copper plugs gapped at 0.8 (BCPR6E)
- and coils taped up like describd in the post above...
A SAFC fixed my problem, but the misfire came back recently...
I just finished taping up my coils, now the mis has completely gone...
Give it a go... it will only cost you 1-2 hours and a couple of $$ in tape...
thanks for the reply zahos, unfortunatlly, taping them up is really only a temporary fix. i have already done that, it helped slightly at high revs but its still got the intermintint miss at idle.
yeah you could possibly be right about the SAFC, it is running a bit rich, so maybe thats the issue. i'm gonna try get hold of a ignitor module today to swap if i can.......
it couldn't be running that rich to cause a miss surely?!?
its basically all stock cept for boost running at 10psi and the fuel pump, and 3" cat back-- that wouldn't cause that many issues would it with the fueling. thou i am getting only like 350km outa a tank but with a bit or hard driving that is...........
Mine was missing like crazy at around 4500-5500 rpm before I intalled and tuned my SAFC. With the SAFC tuned it was as smooth as a baby's arse!
I developed a miss again lately, but that b/c of the coil pack cracking.
Now with the coils taped up.... it's like a baby's arse again
thanks for the help so far guys.
Trust me, thats what it is, what year is your car?
When you boost it, it dumps more fuel in and floods the cylinders.
its a 89/90 R32 with a rb20det
the miss is mostly noticable at idle with it been a constant intermintant one. (like every 3-5 secs) thou is also noticable with the revs held up higher.
I've replaced my iridiums (which looked fine) with brand new coppers, taped all my coils but then replaced #1 + #4 which I believe are the fault 1's with 2nd coils and my problem has gone from 'missing' to now feeling like a few 'flat spots' under load on only 7psi so obviously I still have a coil issue but do you think my car is running rich enough to cause the missfires too ?
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
