57 minutes ago, Joshnew6 said:
I was told that I should gap them down from 0.8 to 1.1m
Other way around.  Stock is 1.1mm, gapped down means smaller, ie 0.8mm.
Gapping them down can (and will) help if the coils just aren't good enough to run against the boost....but these days any misfire should be taken as a reason to upgrade the coils.  Yaris, Audi, R35 GTR, etc are all options these days.
https://www.sau.com.au/forums/topic/476363-r34-problems/#findComment-7900921
This topic will probably help you Josh,
As stated above if smaller gapped plugs don't work you'll need to upgrade your coilpacks, the three options what come to mind are Splitfires (around $500), yellow jackets ($300), or yaris coil pack mod ($150ish)
https://www.sau.com.au/forums/topic/476363-r34-problems/#findComment-7900955
  • 1 year later...
just for closure, I was a newbie to everything to do with Rb's, I was running 25 Psi on E85 with spitfire coils, and the problem ended up being that I was running cheap copper plugs, changed to iridiums and problem solved!!
https://www.sau.com.au/forums/topic/476363-r34-problems/#findComment-7943185
  • 4 weeks later...
  • 3 weeks later...
gapping down to .06mm is suggested when running high boost with e85 does that sound right?
https://www.sau.com.au/forums/topic/476363-r34-problems/#findComment-7945212
0.6mm bro, 0.06mm is not cool!
Yes gapping plugs down is reccomemend if coils aren't powerful enough
https://www.sau.com.au/forums/topic/476363-r34-problems/#findComment-7945216
Note word with emphasis. It's a really weak if. The real recommendation is to improve the coils. Gapping down plugs is a bandaid. Bandaids should not be used where proper fixes exist.
  • Like 1
https://www.sau.com.au/forums/topic/476363-r34-problems/#findComment-7945218
This really doesn't make much sense, unless your copper plugs were old and fouled and the problem was fixed with new plugs. Iridiums dont give you a better spark than coppers, they are just supposed to last longer. But on a modified high performance engine you dont tend to get that longevity out of them and need to replace them more often anyway. The price difference between coppers and iridiums is why most people on here will be running coppers.
But yeh, I agree with GTSBoy here, gapping plugs is SO 2010. Nowadays R35 and Audi R8 conversion kits are a dime a dozen, I'm amazed 'Splitfire' and 'feeler gauges' are still words that people know.
https://www.sau.com.au/forums/topic/476363-r34-problems/#findComment-7945220
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
