Almost perfect condition 9.5/10 only a tiny amount of rash on 2 of the wheels which is barely noticeable.
Have never hit potholes or given the wheels a hard time.
Comes on 235 40 17 federal RSR tyres which I would recommend replacing.
Perfect specs for non gtr skylines.
These wheels are very light and strong, I believe they are around the same weight or even a bit lighter than equivalent spec TE37's.
Regretful sale, would love to keep them but I really need the cash at this point in time.
$1200
Please call or text Sam, 0413 103 732
Located in tarneit, Melbourne IMG_0147.jpgIMG_0148.jpgIMG_0149.jpgIMG_0150.jpgIMG_0151.jpgIMG_0152.jpg
https://www.sau.com.au/forums/topic/476388-enkei-rpf1-17x922/
  • 3 weeks later...
  • 4 weeks later...
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
