Hey guys,
I'm looking for some advice/recommendation on cams for my RB25DET build.
The car will be used as a street/drag car and the goal is to be running in the 10's.
Currently I have Tomei Poncams from my previous setup but looking to upgrade to some bigger cams for a stronger mid to top end.
I contacted both Camtech and Kelford and was recommended the following:
Camtech: 272/272 9mm lift
Kelford: 262/272 9.30/9.35mm lift
Anyone have any experience with one or the other or any advice on which of these cams would be the best option in my case.
The specs of the engine will be:
87mm bore
CP pistons 9.0:1 pistons
Upgraded piston pins
Spool H beam rods
Supertech +1mm valves
Supertech bronze valve guides
Supertech valve springs
Ported cylinder head
ID1000 injectors
CRG twinscroll exhaust manifold
Precision 6466 turbo
Dual TIAL 44mm wastegates
FFP intake manifold
Haltech Platinum pro ECU
Tomei adjustable cam gear (exhaust only)
Small shot of nitrous
Water/Meth injection
Will keep VCT
Will keep hydraulic lifters
Will be running on 98 and 102 pump gas.
Manual gearbox
https://www.sau.com.au/forums/topic/476458-cam-advice-for-rb25-build/
12 hours ago, GTSBoy said:
You'd probably be hard pressed to see the difference between them even on a dyno.  The Kelfords are ever so slightly better for the street, the Camtech possibly ever so slightly better for drag.
12 hours ago, Dose Pipe Sutututu said:
I personally would go for the Kelford, has more lIft.
Thanks guys.
9 hours ago, Figjam Jimmus said:
Do these cams work with the Nissan VCT? Or, are you not running the VCT? Do either cam need head clearance work done?
Yes, they are VCT compatible, I will be running VCT on my build. These are "drop in" cams, so no head clearance required.
On ‎3‎/‎26‎/‎2019 at 9:26 PM, iTzTMG said:
Thanks guys.
Awesome stuff. Both cams seem a very good choice over the "norm" Tomei 256 'drop-ins'.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
