Hey I have a rb25 the short block was built and assembled by a shop. The main mods are cp 9.01 pistons 1.3mm head gasket arp head studs I took it to my tuner and what he said was he  Did a compression test
90-90-100-85-80-80
Cold.
cross hatch don’t look too good on cylinder walls and there was Oil trace  all cylinders and 1st cylinder is at worst
Alot of detonation mark on spark plug 4 to 6
motor only has 7000k on it
it doesnt burn oil never overheated kinda don’t know where to go from here
Edited by dee242
https://www.sau.com.au/forums/topic/476460-rb25-fresh-rebuild-low-compression/
Strap it to a dyno, load hold it at 4k rpm for a good 30 mins
Dump the oil and pop in fresh oil see how it goes, if not rebuild.
I laugh if the "engine" builder didn't clock the rings LOL
39 minutes ago, dee242 said:
How would that happen
How would the rings not get bedded?  It's easy to glaze the bores if you don't know what you're doing.  You have to get an engine up and running very quickly, then have at least a rough enough tune in it to be able to run it at varying revs and load for the first XX minutes.  If you let it sit and idle, like a lot of people have done, then you will glaze the bores and never get the rings to bed in.  From there it is low comp and oil consumption to eternity.
The fix back in the days of rebuilding red motors was a spoonful of Bon-Ami sprinkled down the carby.  Ahh.  The good old days.
  • Like 1
The Bon Ami/Ajax...heard of it and people swear by it, but I've never needed to try it.  They reckoned you used it then flogged the crap out of the motor on a good straight road then watch the smoke out the exhaust until it cleared.
You could try a more commercially available product these days:
https://costeffective.com.au/product/ftc-decarbonizer/
There are others, this is only one of them.....and again, I only heard of them, no idea if they work.
cam timing does impact compression test readings. i would definitley be doing the test hot to see how it goes.
just thrash it, unless there is an actual problem. if the comp test is low but all seems well whats the problem?
Nothing wrong with those numbers....doing a comp test cold is always 'a trap for young players' as the saying goes.  Forgies rattle a bit when cold anyway.
Enjoy your Skyline mate!!!!
  • Like 2
  • Thanks 1
Only other issue now is I get a vibration in neutral when I rev the car after installing a poly transmission mount im not sure if it’s there under load cause the car is waiting to be tuned. But I have changed the harmonic balencer and I don’t think it’s the clutch/ flywheel being loose as  the engine mounts are stock but in good shape
On 3/26/2019 at 9:39 AM, tridentt150v said:
Do it hot first, but not looking good.
agreed - do the comp test once warmed up. like, proper warm. go for a decent drive first. and take all the plugs out and full throttle for each cylinder run. a rb25 cold comp test throttle closed might give you 130, 135 etc when warm and open throttle it will be more like 155 each pot. but yeah those low numbers look pretty baaaddd....
On 3/29/2019 at 8:12 AM, dee242 said:
Hot test came up with
1 145
2 145
3 145
4 140
5 135
6 140
argh i piped up too soon... apologies
the factory manual specifies that lowest acceptable comp is 130 psi each cylinder, with no more than 12% difference from highest to lowest reported value.... so you are within that. happy days  ?
  • Like 1
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
