What suspension you using? I have a '98 Gtst that used to scrape everywhere, it had teins and was pretty low [and f#$king harsh ride].  Also low profiles will do this, so what tyres and rims?
Ages ago I swapped out to bilsteins , king springs. and whiteline bars [SK kit].  This not only improved the ride, but also the handling and lifted the car by around 10-20mm.  Now I rarely scrape.
I admit I could have adjusted the teins up and changed the spring rate, but I still don't think I would have got the ride or handling I now have.
I can measure my front bar height if you want, but where? And normally you measure the wheel arch height from the wheel centreline.
Thanks for the offer, I’ve managed to get an Sspec bumper and it has heaps of clearance. I had to hack it to clear intercooler pipes and the intercooler.
Ive painted it with enamel primer and gloss final coat. Looks ok, but hope it won’t peel off. I only completed a light sand.
A strange thing, I’ll take a photo. one side the bumper fits fine but on the other it bulges out slightly near the headlights.
Do you sometimes have to heat the plastic to helps shape it a bit better?
This is the area that is hard to get to align.
The bumper looks undamaged and the car the car hasn’t been in a bungle.
I tried easing off off the bolts on the other side and trying to push both sides in evenly, but the passenger side is fine but the drivers side bulges out. I can try and put more bolts in but it seems there is something resisting it going back into the right place.
Anyone had had this issue? Or suggestions?
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
