8 minutes ago, Missileman said:
My water pump is starting to leak, do I need to take the lower timing cover and harmonic balancer off to replace the water pump? I'mot doing a major service as the belt and pulleys were done 40K ago.
Cheers Mike.
Yep, all off. It sucks! Make sure you do crank seal while in there, and should do can seals also..
  • Like 1
Cheers Mike.
So....I guess that makes the point that people should always do the water pump when they do the timing belt. Costs 300 more, but saves having to do the job twice. (sorry I know that is no help to you now, but maybe one day someone will search, find this thread, and go, hey, why don't I take that advice!)
Yep, did that, studs bearings and belt, I tend to go with don't fix whats not broken, but can appreciated your advice. How hard is it to remove and replace those cam and crank seals? They look like O-rings if so then a pick tool and a piece of pipe should do the trick.
Edited by Missileman
1 minute ago, Missileman said:
Yep, did that, studs bearings and belt, I tend to go with don't fix whats not broken, how hard is it to remove and replace those cam and crank seals? They look like O-rings if so then a pick tool and a piece of pipe should do the trick.
They aren't orings, don't actullay knoW what the name Of that seal is. The suggested way to get the seals out varies between stab and lever out to screw in a screw and pull out. Being careful not to scratch stuff up of course. I rate it 2/10 on the home mechanic difficulty scale, which is completely in my head and made up on the spot.
Thanks, I'll talk to my support crew... a retired panel beater and his brother the mechanic, the panel beater mate has every fcuking tool you can think of, and a nice bloke too. I wont let him work on my cars as his back is all fcucked up, but he still love giving advice and standing around laughing at my skills.
  • Like 3
And buy a good quality pump and preferably one specific to the 20/25 Skylines.  RB30 ones will fit but they take one less bolt and IMO always end up leaking.  And the cheaper water pumps are Chinese and they don't last either.
  • Thanks 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
