So as the title says I have the TCS, Slip and CEL lights on from the second the car starts. The CEL code is error 21. Doing research it appears to be coil packs. I replaced coils with brand new splitfires and replaced the coil loom with a brand new genuine OEM but the light is still there. Can anyone help me figure out what else could be causing the problem?
Car is a 1998 r34 Gtt
https://www.sau.com.au/forums/topic/476500-tcssliperror-21/
Well, with TCS & slip lights on, it would suggest that you have a problem with the TCS.  So a wheel speed sensor, or the TCS throttle position sensor, or similar.  So, take it to a mechanic and put a proper scan tool on it so you can read the codes in that CU.
Edited by GTSBoy
https://www.sau.com.au/forums/topic/476500-tcssliperror-21/#findComment-7901888
  • 1 month later...
