Australia's total contribution to the world pollution total is 1.3%....so if we go to zero emission there would still be 98.7% total by the rest of the world.  Even cutting our emissions to the targets being talked about [depending on which side you believe] we will only get to a best of 0.3% reduction.
Short answer, if China, USA, Russia, Europe, India does nothing it makes no difference what we do...we are stuffed!!! 1% is not going to save the world!!!!
So when you are at your next drifting/burnout/V8 Supercar/drag etc meeting...ask yourself "Is this really politically correct or necessary given climate change etc?"
If anyone was really serious about climate change [other than as an employment opportunity or a way to make rude amounts of money.....think Al Gore] they would stop Forestry burning huge windrows of trash timber, stop every motorsport event, stop coal, stop B Doubles and every other truck, stop airlines etc etc etc  We'd all be living Amish!!!
Yes our volume of emissions is low compared to other countries, but so is our population.
Here's a link that shows per capita. Why are we so special that we get a free pass on this? As a first world country we should be doing much more than we are.
https://en.m.wikipedia.org/wiki/List_of_countries_by_carbon_dioxide_emissions_per_capita
  • Like 1
Because the majority people are inherently stupid as well as short sighted.
As long as we are happy now we will use plastic, burn fossil fuels, smoke cigarettes, pump raw sewage into the oceans and rivers.
Whilst we are doing this we will happily import goods from third world countries, use their land to grow our crops, their factories to manufacture our goods, and then bash burn and bury their environment and people.
We export fossil fuels/uranium to the third world so they can manufacturer our goods, all whislt at the same time shaming them.
Me, I'm one of the stupid ones, I'm a consumer
  • Like 1
"Me, I'm one of the stupid ones, I'm a consumer."
I'm not any better. I try though. And i do my best to understand climate change. It's something I'm pretty into.
Mate, I try and do my best, sadly my best doesn't really cut it.
I have been "sort of" lucky, born in 1965, I had my first car at 15, I have burnt my fair share of fossil fuels with every conceivable infernal combustion engine there is, but now, as I'm getting older, the YOLO has a few issues, namely, my children.
What will the world be like when my kids are my age, 2050 at this stage looks like it's going to be a shit show.
If you "get in there real deep like" and look at some of the predictions IRT fresh water supply, drought, food supply it don't look good at all.
Meanwhile, I'm contemplating boosting my 86.
I told you I'm one of the stupid ones.
Warning: don't get me started on my views of population growth and how we have come so far past the tipping point it isn't funny
This is an interesting, even though it is outdated.
The Population Bomb is a best-selling book written by Stanford University Professor Paul R. Ehrlich and his wife, Anne Ehrlich, in 1968
Something screwy there....all the countries [except USA] that have a rating of over 10 are very small in population.  I think the way they report on it is way off somehow.  lets face it, Curacao??? Estonia???? Gibraltar??? New Caledonia  Ummm???  I find it hard to believe, something is biasing the samples.  Obviously a per capita report is next to useless in a real world sense.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
