Hi SAU,
As the title suggests, I'm having a weird issue with my 1998 Skyline R34 GTT Auto. Essentially the car will stall out on me when I accelerate maybe past ~10%  throttle at a launch or even turning around a carpark at very slow speeds etc, leading to some semi awkward moments. Car will drive and accelerate fine once it's rolling at say 15km already, I can flat foot it and it'll boost and zoom at full power. Doesn't matter if I'm in Tip-Tronic or leaving the car in "D".
Mods currently on the car that are related:
GTX3076R Gen I Turbo
TurboSmart Kompact plumback
450LPH Fuel pump
Nistune
3" Catback with stock down pipe and cat.
Initially the car had a 100% atmosphere BOV which cased stalling/lugging once coming off boost, took the car to PZP and they sorted out that issue by chucking the TurboSmart BOV on there and re-tuned, currently at 316WHP. I've only had the car for a short period so I'm not sure if the plugs/coils or fuel filter have been changed recently, but I'd like to think they would of shown issues during the dyno tune. I'm new to the RB game and their quirks, anyone have any ideas or possible suggestions?
I was going to swap out the filter this weekend and see what happens, but I doubt it's that as the car runs fine once at speed..
Thanks heaps! really appreciate it :)
Edited by MakkaPakka
7 hours ago, GTSBoy said:
This is not an RB quirk.  You're either losing fuel or spark (either totally, or just enough to stall it).  You should get a laptop (with Nistune) hooked up to it and look at the feedback as you drive it to stall.
You're probably right, I'll try hook a laptop up and see what shows up! Thanks man :)
Except that he said it would go hard if it was already rolling, whereas a soft inlet collapse should prevent that too.
My Sylvia used to do it only on hard takeoffs just enough load to do it but when already moving it didn’t
Sounds like the Alpha N table isn't set properly, put it all at 255 across the rev range. If it's set under 255, on light throttle there's a massive surge of acceleration compensation that's applied.
Also is the stock MAP sensor connected? Nistune goes spastic with it disconnected even though the flags for the sensor are disabled.
  • 4 weeks later...
MAP Sensor is still connected.
Thought I'll give a quick update incase others have a similar problem, had a mate look over it.
Throttle body was pretty gunked up, but also started throwing an engine light for the TPS being shot. Gave the TB a little clean and it helped a bit, car would launch fine from a complete stop but then come an hour or so later it may stall or hesitate, then go back to normal. So the issue became intermittent instead of a 100%
Tried clearing the code but it came back. So at this stage, looks like the TPS and gunky Throttle body could be the problem. I've yet to replace the sensor so I can't say just yet.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
