19 hours ago, KiwiRS4T said:
Dunno but the Freddy plenum on my RB30 fouled the clutch m/c on my Stagea but an R33 m/c solved the problem.
You mean Greddy? Did you install an R33 GT-R clutch master? How much space do you think you have now between the plenum and the m/c?
Not GTR just R33...your mileage may differ being R32. If I were doing it again I would just keep the stock intake.
Interesting, have a look here.
https://www.gpforums.co.nz/threads/463764-White-R33-forums-Need-some-measuring-done
https://www.gtr.co.uk/forum/172742-rb26-jun-plenum-stock-throttle-bodies.html
Seems like perhaps a smaller clutch master may help. Now, the question is, which ones the smallest? So far , the 33 gtst perhaps???
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
