Hey guys and girls,
It's a sad day but I've got to let it go as I've bought a tow car and can no longer keep the Stagea.
I bought the car from Northshore Prestige back in 2011 (65,000km). Been looked after and undercover all its life here, serviced every 5000km.
it has 11months Rego and is priced to sell. $12,000. (204kw@w & 750nm - Still on stock turbo @ 16psi)
I'll start off with the extra's:
Freeway Dolphin vented bonnet $1000ono
G37 Akebono Brakes $2000ono
HKS F-con V-pro ECU with PnP loom $1750ono
the following list comes with the car.........
K&N airfilter with custom power duct airbox mod.
Scotty's Custom 3" Dump pipe.
Full SS X-force 3" exhaust with 100cell cat, resonator and muffler with dual tips.
BC Racing Coilovers, Whiteline Swaybars & Underbody bracing.
17mm Phenolic intake spacer with ceramic coated intake & pipes.
Transgo Shift Kit with B&M trans cooler and thermo fan. (80deg)
HDi 3" Intercooler Kit.
Mishimoto Radiator and 76deg Nismo thermostat.
Scotty's Water coolant mod (opens up the rear water gallery on the back of the block)
Daleo's Custom 2.5" suction pipe.
Scotty's custom 16PSI wastegate actuator.
Turbosmart Dual port BOV.
18x8" Koya RG-Tek rims with RE003's
350Z 3.08:1 LSD diff
HKS? Sandwitch plate and B&M oil cooler with thermo fan. (80deg)
Power steering cooler.
Blacked out AXIS grill / Blacked out front headlights.
AXIS body kit with flairs.
Nismo rear tailgate wing.
V35 Facia with Kenwood DDX4031 Cd player/ Sat Nav/ Bluetooth etc etc
AXIS floor mats & leather everything. Rear boot mat with pull out cover.
Service history summarized.
LSD diff service and installed with new fluid 10/2013
Gearbox flushed 112,500km 4/2016
Rocker cover gaskets replaced 4/2016
Coolant flush & Oil/filter 112,500 4/2016
Spark plugs & Oil/filter 120,000km 4/2017
K&N filter (after the BMC filter died) 124,500km 10/2017
Brake Fluid flush 124,500km 10/2017
Oil & filter 129,000km 2/2019
the belts have been replaced haven't noted down when but lubed every 5000km
O2 sensor & AFM replaced 2017
New battery in 2017.
New front disc's in 2017.
I have a new pollen filter which hasn't been installed yet.
and if your still reading:
2011 - all mod's except ECU 176kw@w on the DVS dyno
2012  - it made 204kw@w on the DVS dyno with a guess of 750nm of torque.
2012 - WISD 1/4 mile - 13.9sec (i think it was at 140km/h)
2014 -  SMSP South Circuit - 1:08 with Nitto Semi slick's
Hopefully i've covered everything but feel free to email me or send a msg (can't answer during business hours)
tmuuldriks at gmail.com
0412 zero seven three 215
Thanks Theo.
https://www.sau.com.au/forums/topic/476550-2002-nm35-stagea-autech-axis/
The only things to gripe about are.......
The Key-less entry doesn't work - I'm guessing it needs a new fob fob for the key as I've replaced the battery and that didn't get it working.
The rear tailgate struts have leaked again, had them re-gassed about 3 years ago ($80) - (might be better off getting genuine)
There is a Dent in the drivers door - easily pushed out via paint-less dent removal. (Photo below)
One of the Parker lenses has fallen out and is floating in the passengers side headlight BUT i have a pair of spare lights here which i haven't got round to pulling apart and painting black.
I think the aerial booster wire has come off or not working as the Radio reception drops out occasionally (Arial is in the rear quarter windows)
Other than that get in and drive the thing!!!!
I don't know how much more motivation you need, look at that sexy bitch AHHAA
These wheels do not come with the car as they are buckled!!!!
Hit me up, have a chat, come for a test drive, bring a deposit - the car will not disappoint..................
  • 3 weeks later...
If you've been sitting on the fence last chance to go for a test drive is this week as the insurance run's out on the 6th of May.
Open to negotiation on price. I'll give it another month and then ill probably strip the car.
Cheers, Theo.
  • 2 months later...
Its a SAD day, the Stagea went to its new home Yesterday, I hope the new owner loves it and looks after it as much as i have......
I know I'm  pretty much the last of the originals so if anyone's left and reading this i thank you all for the journey its been great!!!
This isn't the end for me, i love this club and will continue to be a part of the regular SAUNSW events etc.
Peace, Lambchops!!!
  • Like 2
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
