R33 Boot/Trunk Lid Alignment
Hey Guys,
Had to replace my Boot/Trunk Lid for my series 1 R33 as the other was broken into. Got one from a guy on gumtree pretty cheap but oh man for whatever reason its not aligning and the gaps are huge, can fit my fingers in them. Anyone have any ideas or what the go is? spent hours on it and got nowhere. The main issue is where the taillights and the skyline garnish is.
Not sure if it is because of the aftermarket tail lights.
See attached photos.
Any help would be great guys.
 gaps.thumb.jpg.2274978a4f44deb4d424a5c4308b5321.jpggaps1.thumb.jpg.4bc89fd04a1f5a010a0a08bdbf7fd0d4.jpggaps2.thumb.jpg.de8a2c6410998cf4682d72dc5a3c9e9d.jpg
OK Update found images online and I think the issue may be the aftermarket tail lights. This image of a Skyline currently at jack phillips jdm has similar sort of gaps.
What do you guys think?gaps1.thumb.jpg.547ab59b443befe9bb0896b127c2dd32.jpggaps3.thumb.jpg.702212a1fc339ca6dd50a95e1eae5f0a.jpg
Pretty sure that's normal, it's the side camera angle and the white paint making it look weird I think.
My R33 has the same sort of gap aswell if I look at it from a similer angle. Mines purple with a black boot so not as noticable.
Edited by ossy
It's always bugged me aswell but I'm sure it's normal. My purple R33 has it and so does my brothers. I've also seen several others at car meets as well.
I tried to get a close up of the same angle if it helps.
Edited by ossy
This is getting so annoying. The gaps for my boot are huge and not like others, it's like my boot latch is not catching but it is cause I need to unlock my boot to open it when shut.
I can literally put my whole hand through the gaps and pop open the boot.
If I remove the latch the catches the boot lock the boot sits really well but ofcourse this is not going to work cause I need to lock my boot.
Anyone have any opinions on what's going on here.
Check out these photos. Huge gaps.
Edited by blitzer31
Added more info
Hey adms15,
Yeah I did try that, there isn't much of a difference. Ill try again in daylight and let you know what I come up with.
If anyone knows of any links or help online please let me know, I have googled so much.
Dan
Yeah that bumper is such garbage. I keep leaning on it and the cracks just keep getting worse. Such cheap fibre glass.
I'll check out all my options this weekend and report back.
Dan
  • 1 month later...
Hey guys,
Think I have an idea what the issue is. Removed the bumper and played around with the latches on the boot lid and body but still same. So then I started to look at the after market tail lights and found that possibly these lights may not be 100% correct fitment. Loosened the nuts and pulled the lights out a bit and now its looks normal. What do you guys think? Maybe I can source the original lights and see what happens.
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
