Selling a set (4) of used Tein Super Street Coilovers to suit R33 GTS-T / ECR33 Skylines. I am unsure if these will fit non-turbo models, but I assume they are the same. They are the Japanese spec/version.
Hard to find these now as they are a discontinued item. From memory Fulcrum suspension do service them if revalving is ever needed.
I removed these from my R33 a couple of years ago, as I developed an interest in weekend club racing and put more expensive, track oriented coilovers in. They were functioning fine when removed and have been stored in individual boxes since. Aesthetically, they are in good condition with no rust, only minor roadwear like the occasional paint chip - see photos. I've been keeping them as spares because I tend to hoard my factory parts / anything I replace, but my partner has demanded a garage clean up and these take up way too much space. Can post at buyer's expense or drop off within metropolitan Melbourne.
Tein Super Street are height and damper adjustable coilovers - bolt in and set your desired ride height with a pair of C spanners, then set your desired firmness via simple twist of the valve tops. These coilovers were designed to be a street-friendly compromise that could comfortably take road bumps, but still provide significant handling benefits over stock suspension and aftermarket spring/shock combos - perfect for the daily driver driven with spirit on weekends.
$750 (also listed on Gumtree/eBay for $800)
That or around that from memory^
They were pretty low rates as I wanted something very street friendly at the time.
On 4/16/2019 at 8:43 AM, dee242 said:
Spring rates?
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
