Selling a set (4) of used Tein Super Street Coilovers to suit R33 GTS-T / ECR33 Skylines. I am unsure if these will fit non-turbo models, but I assume they are the same. They are the Japanese spec/version.
Hard to find these now as they are a discontinued item. From memory Fulcrum suspension do service them if revalving is ever needed.
I removed these from my R33 a couple of years ago, as I developed an interest in weekend club racing and put more expensive, track oriented coilovers in. They were functioning fine when removed and have been stored in individual boxes since. Aesthetically, they are in good condition with no rust, only minor roadwear like the occasional paint chip - see photos. I've been keeping them as spares because I tend to hoard my factory parts / anything I replace, but my partner has demanded a garage clean up and these take up way too much space. Can post at buyer's expense or drop off within metropolitan Melbourne.
Tein Super Street are height and damper adjustable coilovers - bolt in and set your desired ride height with a pair of C spanners, then set your desired firmness via simple twist of the valve tops. These coilovers were designed to be a street-friendly compromise that could comfortably take road bumps, but still provide significant handling benefits over stock suspension and aftermarket spring/shock combos - perfect for the daily driver driven with spirit on weekends.
$750 (also listed on Gumtree/eBay for $800)
That or around that from memory^
They were pretty low rates as I wanted something very street friendly at the time.
On 4/16/2019 at 8:43 AM, dee242 said:
Spring rates?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
