So the problem I'm having is that my stock boost gauge on my mdf screen is reading 0.6 bars at idle. I started having the problem after i replace my throttle body and intake manifold gaskets and slightly cleaned my throttle body. I know i shouldn't have cleaned them but i stopped after i read that you shouldn't but my idle isn't high at all. Only problem I'm having is the guage reads boost at 0.6 bars at idle.  i also have a greddy profec that reads -0.5 bars at idle thats hooked up to a mac controller. The controller is hooked up with one hose to the intake plenum near the idle air control valve and the other on is somewhere's else. Its really hard to see and i didn't add the controller or greddy. It was on there from the previous owner. Please help, I'm stumped and don't know what else to do. I'm new to this so please go easy on me...thanks in advance.
Edited by hybridracer504
https://www.sau.com.au/forums/topic/476600-r34-rb26dett-boost-issue/
That is a bit strange, because that just comes from the MAP sensor on the firewall near the brake master cylinder.
Does it work OK when you start to hit boost (ie, does it match the greddy gauge when you are driving)?
I'd start with swapping the MAP sensor for another one to see if it has failed somehow, otherwise there may be some issue in the wiring. The air source is unlikely to be the issue since it is reading high, but you can check the air line is connected to the back of the plenum and has no cracks or splits
Is not the GTR boost gauge MAP sensor supposed to be connected to the little plenum that taps into the intake runners downstream of the throttle plates?  How would it ever read vacuum if it were not?
Agreed....it should be on the manifold (post throttle), not plenum (pre throttle)! Been too long since I've run with one attached. Either way it is not clear to me how it could read higher than atmo unless the problem was electrical not mechanical
I don’t know...it was working fine before I replaced the gaskets. The greddy profec is tapped into the same vacuum line as the sensor. I’ve unplugged the vacuum line for the greddy and it still doesn’t change. I’ve tried driving it down the street but I’m afraid to get on it. Both of the gauges read different. The stock one on the vehicle spikes all the way to 1.2 bars when I tap on the accelerator. What are the ohm readings for checking that sensor? I just don’t want to throw parts at it and not fix the problem
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
