Hi guys,
Just order a NPC7056-10 (organic 300rwkw) for my r33 gts-t.
I also wanted to replace the throwout carrier sleeve and release bearing.
Spoke to Golbey who called NPC and said the 20mm sleeve suits the throwout bearing they supply however a stock sleeve height is 18mm.
Just Wanting to know what a working combo is with a new sleeve carrier and bearing whether I use the npc provided or a Nissan one.
Cheers
2 hours ago, wildeagle44 said:
I have used both stock nissan and npc supplied throwout with that clutch, both work no issue.
Currently have the nissan bearing installed. Friction point is slightly higher up on the pedal, but again, no issues.
Thanks for your response.
Did you purchase a new sleeve carrier
Like this one.https://www.efisolutions.com.au/thrust-bearing-carrier-sleeve-20mm-r31-r32-r33-r34
when you used the NPC supplied bearing as it supposed to be 20mm(bearing width)
Or did you still use your stock carrier sleeve for a R33 should be 18mm https://www.efisolutions.com.au/thrust-bearing-carrier-sleeve-18mm-r32-r33-r34-z33
Interesting you found the disengagement point higher for Nissan bearing as it supposed to be 2mm thinner than the NPC bearing
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
