Hey Guys,
What is going on?
Newbie here, check out my post on the Newbie Introductions page.
So guys I am building this r33 I bought site unseen off the interwebs. The guy told me it has an issue starting amongst other issues.
I will be posting regular updates on here and also posting videos on YouTube of my build progress.
The first issue I will be tackling is the starting issue, I think it may be electrical or fuel related.
what do you think the issue could be. Post your comments below.
Talk soon all
https://www.sau.com.au/forums/topic/476616-dans-r33-build/
  • 4 weeks later...
Hey Guys,
Update battery is all charged but having an issue turning it over. It cranks but wont turn over. Got it to turn over Twice but any acceleration and it will die.
I suspect dud battery or alternator.
Uploaded a video for you guys!
Thoughts?
https://www.sau.com.au/forums/topic/476616-dans-r33-build/#findComment-7904814
Videos not working for me.
Your terminology is confusing.typically cranking and turning over mean the same thing.
You mean it's not starting?but the engine turns over when cranking?or is the engine locked up.? It won't be the alternator, thy does nothing except for charge the batery
https://www.sau.com.au/forums/topic/476616-dans-r33-build/#findComment-7904832
Hey, not sure why the videos aren't working. I'll post on YouTube too. Yeah not starting just keeps cranking but wont start. engine is not locked up. thought it may be battery so installed a new one. would start but very lumpy then cut out.
Tried again, started lumpy revved to 4000rpm saw oil pressure gauge on dash rise and battery light on dash turn off. Stalled at 1000rpm
Battery light is lit on dashboard, pointing me to alternator.
Will try and put a multimeter on the alternator and battery and check. Hopefully it will stay alive long enough.
Any help would be great.
https://www.sau.com.au/forums/topic/476616-dans-r33-build/#findComment-7904834
Update. Forgot to mention, A couple of weeks ago when the car was sitting I started it and found that the car when idling was fluctuating in revs between 650 to 1000rpm. If anyone can piece together all this information for a diagnosis that would be handy.
Thanks!!
https://www.sau.com.au/forums/topic/476616-dans-r33-build/#findComment-7905049
Hey Ben,
Yeah, running a Wolf EMS 3D V4, no airflow meter. Strange car was running fine, then had this idle problem, one week later won't start. annoying.
Changed the battery, cause battery light was lit and other one was old, running a bit low.
I notice that the oil pressure light is also lit on the dash, got it started once over the last two weeks, ran like a lawnmower, coughing and spluttering. Gave it a bit of rev to 4000rpm battery light and oil pressure light went off but as rev's decreased car stalled.
Thanks
D
Edited by blitzer31
added more info
https://www.sau.com.au/forums/topic/476616-dans-r33-build/#findComment-7905054
  • 1 month later...
Hi All,
Thought I would post an update. Car has been moved to my apartment where I have been doing some more work in it.
Completed the following.
  • Replaced bonnet
  • Replaced drivers side door lock actuator
  • Installed boot carpet and trim
  • Replaced a few bits of interior trim
  • Wired in front bumper indicators
  • Started sanding side skirts, boot, bonnet in prep for paint
To be completed
  • Tune - will be done at Sabbadin
  • Run new vacuum lines
  • Paint intercooler piping satin black
  • Install alarm system
  • Pain side skirts, boot, bonnet
  • Boot leaking
  • Weld boot floor pan (due to rust)
  • Replace exhaust
  • Custom air intake
  • RWC
  • Club Reg
Hopefully she will be on the road by Summer
Will keep you guys updated.
Dan
https://www.sau.com.au/forums/topic/476616-dans-r33-build/#findComment-7910486
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
