Hey Guys,
What is going on?
Newbie here, check out my post on the Newbie Introductions page.
So guys I am building this r33 I bought site unseen off the interwebs. The guy told me it has an issue starting amongst other issues.
I will be posting regular updates on here and also posting videos on YouTube of my build progress.
The first issue I will be tackling is the starting issue, I think it may be electrical or fuel related.
what do you think the issue could be. Post your comments below.
Talk soon all
https://www.sau.com.au/forums/topic/476616-dans-r33-build/
  • 4 weeks later...
Hey Guys,
Update battery is all charged but having an issue turning it over. It cranks but wont turn over. Got it to turn over Twice but any acceleration and it will die.
I suspect dud battery or alternator.
Uploaded a video for you guys!
Thoughts?
https://www.sau.com.au/forums/topic/476616-dans-r33-build/#findComment-7904814
Videos not working for me.
Your terminology is confusing.typically cranking and turning over mean the same thing.
You mean it's not starting?but the engine turns over when cranking?or is the engine locked up.? It won't be the alternator, thy does nothing except for charge the batery
https://www.sau.com.au/forums/topic/476616-dans-r33-build/#findComment-7904832
Hey, not sure why the videos aren't working. I'll post on YouTube too. Yeah not starting just keeps cranking but wont start. engine is not locked up. thought it may be battery so installed a new one. would start but very lumpy then cut out.
Tried again, started lumpy revved to 4000rpm saw oil pressure gauge on dash rise and battery light on dash turn off. Stalled at 1000rpm
Battery light is lit on dashboard, pointing me to alternator.
Will try and put a multimeter on the alternator and battery and check. Hopefully it will stay alive long enough.
Any help would be great.
https://www.sau.com.au/forums/topic/476616-dans-r33-build/#findComment-7904834
Update. Forgot to mention, A couple of weeks ago when the car was sitting I started it and found that the car when idling was fluctuating in revs between 650 to 1000rpm. If anyone can piece together all this information for a diagnosis that would be handy.
Thanks!!
https://www.sau.com.au/forums/topic/476616-dans-r33-build/#findComment-7905049
Hey Ben,
Yeah, running a Wolf EMS 3D V4, no airflow meter. Strange car was running fine, then had this idle problem, one week later won't start. annoying.
Changed the battery, cause battery light was lit and other one was old, running a bit low.
I notice that the oil pressure light is also lit on the dash, got it started once over the last two weeks, ran like a lawnmower, coughing and spluttering. Gave it a bit of rev to 4000rpm battery light and oil pressure light went off but as rev's decreased car stalled.
Thanks
D
Edited by blitzer31
added more info
https://www.sau.com.au/forums/topic/476616-dans-r33-build/#findComment-7905054
  • 1 month later...
Hi All,
Thought I would post an update. Car has been moved to my apartment where I have been doing some more work in it.
Completed the following.
  • Replaced bonnet
  • Replaced drivers side door lock actuator
  • Installed boot carpet and trim
  • Replaced a few bits of interior trim
  • Wired in front bumper indicators
  • Started sanding side skirts, boot, bonnet in prep for paint
To be completed
  • Tune - will be done at Sabbadin
  • Run new vacuum lines
  • Paint intercooler piping satin black
  • Install alarm system
  • Pain side skirts, boot, bonnet
  • Boot leaking
  • Weld boot floor pan (due to rust)
  • Replace exhaust
  • Custom air intake
  • RWC
  • Club Reg
Hopefully she will be on the road by Summer
Will keep you guys updated.
Dan
https://www.sau.com.au/forums/topic/476616-dans-r33-build/#findComment-7910486
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
