Hi,
I think my blitz is leaking and have seen many people saying they are known for leaking
I am saying this as i get random boost around 14 psi and sometime it goes to 16-17 but other times stays at 14-15
prior to tunning had the same problem as it was reaching 6 psi where it should have been 9 psi . even worse it was on 1-3 psi if the car was off road for 2-3 month which lead me to believe blow off valve internals needed a bit of drive ...
anyway I could be wrong and to test it, I am buying a new BOV,. greddy
i have looked at the mounting plates and it seems to be the same for blitz and greddy( see below).
is there a standard between the BOV so they have have same aparture / hole size so I could use my blitz valve ?
also would you use gasket maker for the connection between pipe and dump valve ?
blitz
https://www.ebay.co.uk/itm/Blow-Off-Valve-Adapter-Fits-Blitz-BOV-For-Nissan-Skyline-R32-R33-R34-GTST-GTT-BK/273349837940?epid=24021312519&hash=item3fa4eb8474:g:yBUAAOSwnEtbRbzU
greddy
https://www.ebay.co.uk/itm/401678163818?ViewItem=&item=401678163818
https://www.sau.com.au/forums/topic/476620-blow-off-valve-plate/
10 minutes ago, drifter17a said:
can't as haven't got anything to block it off in addition to potentially damaging turbo due to pressure!
You don't have a coke can?
I'll ignore the turbo pressure damage concern for the most part, but I will guarantee doing it for a test won't cause an issue.
changed to greddy and i was very happy as boost built to 17 psi but that was short lived as it soon dropped to 15.4 psi again as soon as car was hot.
need to speak to tuner
i spoke he is using air temp to adjust fuel and boost so don't have too much boost when hot
Where is your boost reference? Inadequate IC setups will often lead to boost not being maintained after heat soak.
However, if you were to take your boost reference post IC you kind of masks those symptoms, another reason factory Nissan engineers took a boost reference post IC as well.
5 hours ago, drifter17a said:
What is ic? Intercooler?
mine is on intake manifold
yep, kinda common reduction
I do not understand what's the fuss about it. just put ur blow off in front of the throttle and that's it, everything will work perfectly
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
    • I couldn't agree more. As an owner of a built high HP skyline, I'd be a hypocrite to not buy a Hummer for the reasons you listed though haha.
    • Hahaha oh shit! Again!
