I have a 2001VW Passat. Last year I changed the original head unit and replaced with a Sony head unit.
On the original head unit I got good reception on both FM and AM frequencies.
When I changed the head unit I noticed on AM the reception was almost non existent. I don’t listen to AM very much so I had no issue with it. Recently two FM radio stations (triple m and gold 104) have started to get poor reception while all other stations are fine.
I have checked connection at the back of head unit and replaced the plug that connects the antenna cable into the head unit as it was a little loose. No help.
I bought a $25 screw in antenna from supercheap to see if that made a difference thinking maybe faulty antenna. It was actually much much worse with the new screw in antenna and pretty much lost all reception.
Has anyone else had this issue? Could it be faulty head unit? Any advice would be appreciated.
https://www.sau.com.au/forums/topic/476634-issues-with-radio-reception/
Check your grounds on the head unit wiring and clean up the antnenna connections as well.
Potentially your antenna connection is simple coming loose from the head unit.
RF shorts could also be your problem. Any antenna cable that has been crushed or turned beyond the bend radius (ie 180 degrees), will no longer work correctly.
As the old saying goes, one will rise abruptly based on its accumulated strength. In 2016, the PCB industry in China has made the best achievement among the overall global PCB industry with not only the largest scale but also good economic efficiency, and the overall industry chain is making fundamental changes. As long as grasping the opportunity of industrial upgrading well, in the future, China’s PCB industry is certain to enjoy a stable and rapid development and actively expand the market under the driving force of the overall industry.
This is a terrible reponse to a genuine question. Are you spruking PA chipsets or FM transceivers? No?... maybe keep it to yourself next time.
'twas spam of the best sort.
    • My purchase experience was no where near as glorious as yours but still a significant moment in my life! Yeah that's a bit of a dilemma as to whether you bring it back or not!  Obviously a massive waste of time and effort to bring it back if you're only going to move there anyway!
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
