Good evening all, was driving around town and car stalled during the drive. Got the car parked and narrowed down the issue to the fuel pump not priming or turning on at all.
For starters: 1990 BNR32, Apexi ECU and Power FC, Deatschwerks fuel pump.
To sum up all the troubleshooting I've done:
  1. Shot power for fuel pump relay and coupling to cap of tank, 12v of power is provided for a second, then relay shuts off providing no power. (while key is in on position)
  2. Installed R33 GTR fuel pump and once again pump is not priming.
  3. Fuses all intact.
  4. Provided direct power to Deatschwerks fuel pump, pump did not turn on. (Gonna get a new pump)
  5. Swapped batteries to a new one.
Any recommendations going forward to try and narrow down this electrical gremlin? Is there a fail safe where the relay will not provide constant power if a pump is not installed?
Thanks!
https://www.sau.com.au/forums/topic/476645-bnr32-gtr-fuel-relay-problem/
Look at the wiring diagram out of the service manual. The pump is controlled by the ECU, so you need to understand where the wires come from to know when they should be powered/earthed.  Randomly jumping power into the relay circuit is not necessarily going to help, and may do the opposite.
I had hot starting problems after installing a larger fuel pump and larger grounding relay. It ended up being the original fuel pump module not wanting to send the correct signal to the pump. Once the module was bypassed, car now starts when hot without issue.
Just another thing to consider.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
