Sold my car so clearing out parts collected.
*Parts for r34 coupe rwd unless otherwise mentioned.
*Parts are in used condition unless otherwise mentioned.
roof lining $50
driver seat parts $30
rear interior trim (excellent) $200
air conditioner condenser $100
rear seats $200
r34 hks sld $150
silver bumper front $200
white bumper front $200
coupe silver bumper rear $200
coupe black bumper rear $200
r34 power fc/hc/boost kit $1000
nismo 480cc injectors $400
custom cat back exhaust $800
custom dump pipe rb25 flange $200
custom dump pipe garrett iw flange $200
shockworks coilovers $1200 - on hold
dms coilovers $1700
sydneykid bilstein suspension $800
whiteline front/rear swaybars $400
cusco front upper camber arms $400
gt3076 0.82 iw garrett $1200
gtx3071 0.63 iw garrett $1200
mamba rb25 iw rear 0.73 new $200
race radiator dandenong radiator $300
trust return intercooler $400
trust oil cooler $800
coupe qm1 pass door $200
coupe kv2 pass door $200
coupe kv2 driver door $200
z32 afm $150
splitfire coilpacks $400
pass mirror $100
passenger rear quarter glass $200
bear 4wd r34 rear cradle/subframe $200
qm1 coupe boot lid (wing holes) $250
coupe tail light pass driver $250
pass rear quarter glass $200
oem rb20/rb25 exhaust manifold $50
kaaz 1.5way lsd centre $800
PWR core custom vertical flow intercooler $600
NEW driver rear quarter panel $900
NEW driver and passenger rear inner guards $600
NEW nissan r34 turbo gearbox from justjap $3200
NEW halogen r34 driver headlight $400
NEW halogen r34 passenger headlight $400
NEW derali oil sandwich plate (made in usa, thermostat) $80
Racepace r33 rb25det motor (forged, n1 water/oil) laid up with oil $3000
q45 throttle body $200
q45 air flow meter $150
v35 sedan headlights (halogen) $350
v35 hks sld $250
v35 bilsteins (need painting) $300
v35 sedan bumper (2005) air guides $100
NEW v35 kyb dampers $400
Pickup in Croydon.
Parts may be listed elsewhere.
PM if interested.
  • Like 1
  • 1 year later...
On 02/07/2020 at 7:14 PM, mutex said:
Fyi, the parts I have left I've listed on gumtree.
https://www.gumtree.com.au/s-seller/mark/1001639920
Cheers.
hi mate, would you happen to have a r34 gtt bonnet by any chance?
Thanks
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
