FS: r34 coupe + other parts garage sale
Sold my car so clearing out parts collected.
*Parts for r34 coupe rwd unless otherwise mentioned.
*Parts are in used condition unless otherwise mentioned.
roof lining $50
driver seat parts $30
rear interior trim (excellent) $200
air conditioner condenser $100
rear seats $200
r34 hks sld $150
silver bumper front $200
white bumper front $200
coupe silver bumper rear $200
coupe black bumper rear $200
r34 power fc/hc/boost kit $1000
nismo 480cc injectors $400
custom cat back exhaust $800
custom dump pipe rb25 flange $200
custom dump pipe garrett iw flange $200
shockworks coilovers $1200 - on hold
dms coilovers $1700
sydneykid bilstein suspension $800
whiteline front/rear swaybars $400
cusco front upper camber arms $400
gt3076 0.82 iw garrett $1200
gtx3071 0.63 iw garrett $1200
mamba rb25 iw rear 0.73 new $200
race radiator dandenong radiator $300
trust return intercooler $400
trust oil cooler $800
coupe qm1 pass door $200
coupe kv2 pass door $200
coupe kv2 driver door $200
z32 afm $150
splitfire coilpacks $400
pass mirror $100
passenger rear quarter glass $200
bear 4wd r34 rear cradle/subframe $200
qm1 coupe boot lid (wing holes) $250
coupe tail light pass driver $250
pass rear quarter glass $200
oem rb20/rb25 exhaust manifold $50
kaaz 1.5way lsd centre $800
PWR core custom vertical flow intercooler $600
NEW driver rear quarter panel $900
NEW driver and passenger rear inner guards $600
NEW nissan r34 turbo gearbox from justjap $3200
NEW halogen r34 driver headlight $400
NEW halogen r34 passenger headlight $400
NEW derali oil sandwich plate (made in usa, thermostat) $80
Racepace r33 rb25det motor (forged, n1 water/oil) laid up with oil $3000
q45 throttle body $200
q45 air flow meter $150
v35 sedan headlights (halogen) $350
v35 hks sld $250
v35 bilsteins (need painting) $300
v35 sedan bumper (2005) air guides $100
NEW v35 kyb dampers $400
Pickup in Croydon.
Parts may be listed elsewhere.
PM if interested.
  • Like 1
  • 1 year later...
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
