I have been to broke to do anything to the GTR the last few weeks hence the lack of updates, but finally getting a few items picked up this weekend hopefully.
I am currently looking into how I am going to restore the bolts and nuts, brackets etc used around the whole car, namely suspension at this stage.
My plan of attack is currently to purchase a vibratory tumbler and zinc plating setup. I also have access to a small sand blaster for items that won't fit within the tumbler.
Vibratory Tumblers, also known as case tumblers are available at gun shops so will pick one up in town for $95 in the coming weeks. Much like the one below on ebay.
At this stage I believe a walnut media will be suitable for getting the right finish on the hardware. If anyone has experience with tumbling bolts etc some advice would be sweet.
https://www.ebay.com.au/itm/Max-clean-3-5l-Electronic-Brass-Case-Tumbler-Reloading-Media-Cleaning-Case-Clean/183475533028?epid=22026939511&hash=item2ab7fe74e4:g:Df8AAOSwZw1buslt
 https://www.caswellplating.com.au/store/store.php/products/copy-cad-or-zinc-plating-kit-6-litre
Once zinc plating is completed, I am thinking that using a black chromate on them will be an awesome final touch.
https://www.caswellplating.com.au/store/store.php/products/black-chromate-concentrate
an example of a zinc then chromated bolt is attached. Much better than painting.
Hopefully on monday I will pick up the front rolling gear. I would start stripping this straight away to prepare for resto but I actually need to take the car to a fabrication workshop in the next month or so for some work to get done on the frame rails (classic dented in 32 things i'm sure you are all aware of haha).
So unfortunately I will be putting the front subframe, suspension etc in the car at this stage. I will also be putting in the rear subframe out of the red gtst just so it rolls and can get on the trailer to go to the workshop.
Also picking up something for the eventual engine tomorrow, 10 hr drive ahead of me.
Edited by Tenny
Alrighty, so this weekend was mega expensive and im feeling it haha.
Ended up taking a 10 hr round trip to bundaberg to pick up some 26 covers. Was a decent price so can't complain.
Then yesterday i went to jdm autoparts in brissy to get:
Front subframe, body loom, attessa ecu, attessa res, subframe mounting bracket thingies, speedo cable, etc.
Then, last night i decided to order a brand new front lip off justjap because nismo heritage has more than doubled the price. RIP. Justjap had some for $600.
Also thought id order the front bar and indicators from kudos which is another $900.
Will get those in the next few weeks but will be storing for a long time yet ha.
Next on the agenga will be to get the car rolling so its ready to go to brissy for some work on the rails.
20 minutes ago, Robzilla32 said:
26 minutes ago, jmknights93 said:
The front lip price jump is very annoying and shame on Nissan for doing that... They've been available for years...
Tell me about it. The price on Kudos has doubled.
got on my nerves a little bit. Totally a cash grab. hence Im getting the front bar..before it goes up too.
The "N1" bar totally not worth the extra coin considering the vent holes look as though they've been cut by a 5 year old with a die grinder. I've attached a great reference image that I found on the forum a few years ago in case you were going that route?
Yeah, not getting the N1 bar, just normal GTR. My gtst has a genuine N1 bar on it which I bought brand new in 2015 - $250 haha. I also have a genuine N1 reo i bought at the same time for $250 thru nissan as well.
If I can't find a 32 gtr front reo for a decent price, I may steal the N1 from my gtst. The normal GTR bar will fit fine on that.
  • Like 1
Going price for front reo bar used at the moment is around $700 - $1000, USED !!!! That was everywhere I've checked as I was after one, but fk that ! Good pic of the N1 cutouts too, just about to do it myself.
  • Like 1
2 minutes ago, r32-25t said:
You can get a brand new r33 one for 580 and is same as a 32 n1 reo apart from where the mounting holes are drilled, with a bit of measuring can easily be redrilled to fit
Did see that. pretty cool trick.
16 hours ago, Tenny said:
Just jap was $15 to ship from Sydney to Toowoomba..
Ah well that has changed significantly.  I had another look and the freight is now down to less than $100.  So I guess what Iw ould have paid in freight now goes on the part.
Did you get enough bolts with the lip to attach it or just a handful or do you have to order them separate?
Not too sure didn't have a proper look. But id say it would be enough to mount it properly. It just came with the lip i didn't order anything separately.
Got around to picking up rear subframe and put them both in this arvo so it will roll on the trailer for rail / sandblast work.
Its still a shelf at the moment unfortunately but hope to get some pallet racking or similar soon to make better use of the area. About to lose over half my shed to new home owners :(
Does anyone bave reccomendstions for a good vlaster in brissy / seqld area that can do the engine bay, boot floor and window trims etc?
  • 2 months later...
Don't have much of an update unfortunately.
In the process of buying a house so time and money has been elsewhere recently. I have sold all my other cars (green r32 and r31) so i only have the gtr to focus on now once im setup in the new place.
Renovations are needed at the house too so im sure this will slow down even more unfortunately :(
Thought i might chuck up a few photos just to show that nothing has changed ?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
