Hey all,
Is there anyone locally who is highly regarded in building and advising on GTR suspension set-ups or am I going to have to work with someone in Sydney?
I'm about to put my 32 on the rotisserie and while the subframe is out, I'm going to pull it apart completely and rebuild/have someone else rebuild all suspension and handling elements, before re-uniting it with the chassis. I'll most likely have MCA build the coilovers (have them on my GC8 and am happy with them) but it's all the other stuff I'm seeking advice on (bracing, bushes, brackets, swaybars, links etc).
Recommendations?
Thanks. Andrew.
https://www.sau.com.au/forums/topic/476657-suspensionhandling-specialists/
Hi Andrew, what is the target use for the car? Clean road car and spirited driving? Or something more specialist.
If the former, and noting you are going to the effort of rotisserie, replace every ball joint, rod end and bush with factory or aftermarket items. New, factory style is fine for that sort of use but if you want improvements then caster rods, front upper control arms and hicas lock out are the main things.  If you are going MCA for shocks they will recommend springs to match (generally quite heavy) and so you would either use stock or light upgrade sway bars.
If it's for drag, drift, circuit race or rally they are all more specialist discussions.
Thanks Duncan.
Car will be a semi-daily (dry weather days), but would like the setup to be capable of competing in Targa events and similar. Power figure will be circa 600kw ATW on pump98, so the suspension will need to be capable of keeping the car heading roughly in the right direction (appreciate that my right foot is primarily responsible for this).
Is there anyone you know of who could advise on specific products? My challenge at the moment is knowing which brands to use for which specific areas, to build a holistic package. i.e. are Nismo control arms preferable to Ikeya Formula control arms etc (and the same questions for each part of the setup).
Notoras Motorsport are down in Fyshwick and have set up some pretty serious japanese cars, mainly known for their work on Evos and Hondas, but im sure they have worked on Skylines also.  Could be a good starting place?
https://www.facebook.com/pg/notarasmotorsport
https://www.notarasmotorsport.com.au/
Inline suspension in Queanbeyan have good feedback also, as well as Racing Ready motorsport in West Belconnen.
https://www.truelocal.com.au/business/inline-steering-and-suspension/queanbeyan
https://www.racingready.com.au
Edited by JGTC
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
