I was looking at purchasing these for my R33: https://carbonetics.net/index.php?route=product/product&path=339&product_id=6813
I know they are chinese copies, but are they any good? I am looking for new seats for my r33 which hold better, I was considering R33 GTR seats but cannot find any in good condition for less then $1000 a seat.
Do any brides have ADR compliance?
https://www.sau.com.au/forums/topic/476672-bride-seats-for-r33/
Are you willing to risk your life in them?
If you crash your insurance company won’t pay you anything for having a non compliant item fitted to your car
Have you tried searching yahoo auctions japan for genuine r33 seats?
  • Like 1
Custom fabricated or genuine rails only, another question you should ask is that do you see any WTAC guys cheap out on seats or harnesses?
And no aftermarket seat is 100% ADR, all the advertised crap is just that crap. None of these seats go through crash testing.
For a street car, you can't beat stock GT-R seats from R32 to R34.
Yes I have searched buyee.jp for r33 gtr seats and cannot find anything. I won't buy these, but a lot of JDM parts are not ADR Compliant some of which I have on my car like TEIN coilovers, BLITZ front mount etc etc.
Where can I find some? Any other suggestions on good seats from the likes of Recaro or Sparco? In saying that neither of these are adr compliant are they?
Yes and if you crash and these are on your car and your insurance doesn’t know or hasn’t agreed to cover them then there is a high chance that you will not receive a payout and have to cover any damages from your own pocket
Ok, the seats arrived on Friday. Have to say I am very impressed with the build quality being essentially a Chinese rip off. The recliner is strong and feels robust and the seat is comfortable and holds very well surprisingly. I bought the rails from the same manufacturer I linked in the OP and everything was bolt in. Can't complain for $650 shipped.
Did you pull the seat base apart to have a look at the quality of the welds on the frame?
I did when i had one and was horrified with what i saw. There was holes burnt through the thin metal and instead of throwing it out and starting again they just tacked inside the hole.
Some reps are ok, others are not. You should definitely give the lower base and welds a thorough inspection. You will need to remove the lower fabric and padding. Pretty easy to take off and put back on.
This is assuming they're reclineable and not bucket seats.
  • Like 1
  • 11 months later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
