I was looking at purchasing these for my R33: https://carbonetics.net/index.php?route=product/product&path=339&product_id=6813
I know they are chinese copies, but are they any good? I am looking for new seats for my r33 which hold better, I was considering R33 GTR seats but cannot find any in good condition for less then $1000 a seat.
Do any brides have ADR compliance?
https://www.sau.com.au/forums/topic/476672-bride-seats-for-r33/
Are you willing to risk your life in them?
If you crash your insurance company won’t pay you anything for having a non compliant item fitted to your car
Have you tried searching yahoo auctions japan for genuine r33 seats?
  • Like 1
Custom fabricated or genuine rails only, another question you should ask is that do you see any WTAC guys cheap out on seats or harnesses?
And no aftermarket seat is 100% ADR, all the advertised crap is just that crap. None of these seats go through crash testing.
For a street car, you can't beat stock GT-R seats from R32 to R34.
Yes I have searched buyee.jp for r33 gtr seats and cannot find anything. I won't buy these, but a lot of JDM parts are not ADR Compliant some of which I have on my car like TEIN coilovers, BLITZ front mount etc etc.
Where can I find some? Any other suggestions on good seats from the likes of Recaro or Sparco? In saying that neither of these are adr compliant are they?
Yes and if you crash and these are on your car and your insurance doesn’t know or hasn’t agreed to cover them then there is a high chance that you will not receive a payout and have to cover any damages from your own pocket
Ok, the seats arrived on Friday. Have to say I am very impressed with the build quality being essentially a Chinese rip off. The recliner is strong and feels robust and the seat is comfortable and holds very well surprisingly. I bought the rails from the same manufacturer I linked in the OP and everything was bolt in. Can't complain for $650 shipped.
Did you pull the seat base apart to have a look at the quality of the welds on the frame?
I did when i had one and was horrified with what i saw. There was holes burnt through the thin metal and instead of throwing it out and starting again they just tacked inside the hole.
Some reps are ok, others are not. You should definitely give the lower base and welds a thorough inspection. You will need to remove the lower fabric and padding. Pretty easy to take off and put back on.
This is assuming they're reclineable and not bucket seats.
  • Like 1
  • 11 months later...
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
