5 minutes ago, BK said:
And you'll kill another one. There isn't any difference in strength, the synchros are just revised slightly for better shifting. There is bugger all difference between the boxes really, I don't know why Nissan even bothered. About 10 parts were changed.
Ok good to know anyone know what the go to brand is for gearsets these days ? As it's still street driven would be better just doing 1st to 3rd ? And keep 5th as is ?
Ps if anyone has a second hand sequential I may been interested !!
Edited by danny14
On 23/05/2019 at 3:55 PM, joshuaho96 said:
For a street car would you guys recommend the 3 gear set instead of 5 gears? I don't like how the 5th gear is shorter, as-is the engine turns ~3000 RPM around 130 kph.
On 23/05/2019 at 4:10 PM, BK said:
Yeah that's the go and what I still use in the 33. If you get the 3 speed kit with uprated input shaft it ends up being strengthened 1st - 4th gears with a standard 5th, as the input shaft is essentially 4th as it is the 1:1 direct gear.
The OS Giken 5th is more for circuit racing being shorter.
So an Os gearset over a Par set is the recommendation?
Probably a dumb question but looking at my attachment which one should I order? The heavy duty input shaft or the holinger type?
Cheers
Edit: I don't have a clutch yet so will probably go with the Holinger type and an R3C
Edited by 33SOM
Cheers
What site are you on mate and what gearset is that
Cheers
Did you get a quote from them posted to aus with taxes ?
On 08/06/2020 at 3:01 PM, BK said:
OS Giken gearsets are now confirmed in stock again at RHDjapan if anyone is still looking.
A few key points I'll mention about those wanting a Giken gearset which are usually overlooked. There was a reason I posted this - they have been very hard to get and RHD seems to be the pick for supply. They are in stock now, but next shipment is September or October if you miss out. Also those Greenline prices will absolutely not be updated, their site is terrible for this. This is about the cost breakdown of doing a box just for you guys thinking of doing one -
The kit with input / no 5th is about $4.3k and with 5th about $5k before tax or shipping. With Covid-19 at the moment means no EMS from Japan either, so only shipping option will be by international courier = expensive. Usually DHL, which means you absolutely will pay GST as DHL are pricks for always picking this up.
If you've got an old box budget about $1000 for series 3 upgrade parts and about a 1 - 2 month wait. Want a centre plate (recommended) ? Budget another $1200 - $1500. Want a GM / Holinger 26t spline upgrade ? Special order input shaft, and custom machining out of your existing gearbox front cover another 3.5mm diameter to fit it. Cost $500+
Can't get box in and out of car yourself ? $500 from workshop for box out. Same again for box back in, $500. Can't assemble gearset yourself ? Minimum $2k box strip and reassembly.
Getting pretty close to a $10k box now, without a clutch.
....and they do break.
I'm in a bit of a interesting situation at the moment as well, I currently have a ppg 5sp s/c dog box in bits waiting on parts from ppg which may be upto a 3 month wait, so I'm torn on do I sell it as is or do I wait and fix it, out of all the options par seems to be best local option at the moment.
my questions is should I sell the gearset and buy something new or do I wait and fix it and give someone a good deal?
?me
poor assembly, caused me to have shifting issues with the shifter coming out of the trans during high load shifts and even miss selected a gear a couple time when the shifter came out.. I'm lucky I didn't fold my motor in half
yeah it was a shame as I only did 500km's before I decided to pull it and check it out luckily as it would have caused more damage. I'm torn between building a o/s syncro box, and this dog box as I love the whine and dog engagement as when you get a good shift its just awesome at how fast and direct it is.
That won't cause flames as a sequential box is always going to be superior on the circuit, but that's not necessarily what we're all talking about is it ? It's a far too simplistic view, as not everyone wants a Sequential or dog box.
Some people want helical gears, some straight cut gears. Some want synchro, some want dog engagement. But some people want an H pattern, or any combination of the mentioned configurations in a transmission. Driving an H pattern, synchro box on street is always going to be the easiest box to operate. I happen to like straight cut gears and dog boxes, but I like H pattern too.
Albins and Holinger have been proven to make quality gear, but being sequential doesn't automatically mean stronger by definition. I hope your not under the impression you are going to spend $25k - $30k on a box and it be indestructible. The sequentials are not a set and forget fix, require regular teardowns like any dog engagement, and they also can break just like any other box. A sequential would be the last thing I would want, or need, on a mainly street driven car.
  • Like 1
Rebuild it for sure.
Ok...
So why does it seem hard to get details on the cost to maintain the dog box's ?
I read very mixed info of needing new dogs every 5k, some to most gears seem to have dogs built in, so your buying a full gear.
Almost no on advertises the cost of gears and you feel like your wasting peoples time to call when you are in options mode.
A real street car in my mind is going to do 10,000k a year and your looking at one or two gearbox overhauls ?  At xx price ?
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
