3 piece forged NOX wheels 20x10.5 +12 off my R34 GTR gloss black dish satin black centre falken tyres front tyres are almost new ,rears are fairly new ,stud patterns 5x114.3 $3000
R34 GTR mechanical non vspec diff 3:545 ratio with nismo 1.5 way diff centre assembled by award diff $2999
Brand new Alpha&omega 350mm rear brake kit evo 8 rear calipers powdercoated white ,geniune brembo brake seals ,dba t3 4000 brake rotors ,winwax w3 pads and braided brake lines to suit $1999 hasnt been used since fitted
Brand new high octane racing billet rear driveshaft inserts $1000 or if someone wants a full set $2000
Rare R34 gtr non vspec crown wheel and pinion 3:545 ratio ready for a aftermarket diff centre will fit into any non vspec diff housing will throw in other spares everything that in the container are all 34 non vspec pieces $750
Brand new Plazmaman 85mm throttle body with hdi clamp welded on with s15 throttle cable to suit $750
Brand new Precision 66mm wastegate brand new in box $665
R34 gtr back half of tailshaft $350
R32 gtr front half of tailshaft $250
R34 gtr power steering hardlines with brand
new pressure switch $250
R32/33 gtr drivers side front shaft suits reco $200
2x Geniune BBS LM F1 black and gold centre caps $150
R34 gtr factory wheel nuts full set 20 pieces $50
R32 gtr gearbox crossmember $50
R34 gtr/gtt boot brake light $50
Rb26 bottom timing cover $50
Rb26 backing plate $50IMG_8403.jpgIMG_8404.jpgIMG_8405.jpgIMG_8425.jpgIMG_8436.jpgIMG_8419.jpgIMG_8418.jpgIMG_8420.jpgIMG_8424.jpgIMG_8430.jpgIMG_8412.jpg
https://www.sau.com.au/forums/topic/476753-gtr-part-galore/
Brand new Alpha&omega 350mm rear brake kit evo 8 rear calipers powdercoated white ,geniune brembo brake seals ,dba t3 4000 brake rotors ,winwax w3 pads and braided brake lines to suit hasnt been used since fitted $1750 or will swap for r32 33 34 gtr rear brembo kit calipers pads rotors and brake lines with $1000 my way
Brand new Precision 66mm wastegate in the box $650
Brand new Plazmaman 85mm throttle body with hdi clamp welded on ,throttle cable included $600
R34 gtr non vspec crown wheel and pinion 3:545 ratio it will fit into any non vspec diff housing $550 will throw in a housing so all you need is a aftermarket diff centre and off you go
R34 gtr back half of tailshaft $300
R32 gtr front half of tailshaft $200
new pressure switch $200
R32/33 gtr drivers side front shaft suits reco $150
2x Geniune BBS LM F1 black and gold bbs logo centre caps $120
Rb26 girdle $50
https://www.sau.com.au/forums/topic/476753-gtr-part-galore/#findComment-7904902
  • 1 month later...
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
