NISSAN R33 PARTS
TypeM front Bumper = SOLD
Stock rear Bumper = SOLD
Stock Bonnet = SOLD
Stock Suspension and springs (GC) = Make an offer
Apexi lowered Heavy duty Springs = Make an offer (will separate)
Stock Steering wheel (series1) = Make an offer
Cat back exhaust = Make an offer
Stock rear spoiler (series1) = Make an offer
FrontMountIntercooler Kit w/piping (600x300x75 Core)(BrandNew) = $1100.00
Stock front indicators (series1) = Make an offer
Stealth rear wing (Flat spoiler)(BrandNew) = $320
1 x Passenger side indicator/fog light = make an offer
Stock side indicators = Make an offer
Stock Gear Knob = Make an offer
WHEELS
Set of 15" wheels with VG tyres (Good for drifting)(4/114) = $100.00
17" Sparco 6 Spoke rims with brand new tyres(215=Front)(225=Rear)(4/114) = $800.00
15” Nissan S13 SR rims and tyres (Good tyres)(4/114) = $250.00
17" HR Racing Concept9 shaddow chromes with tyres (4/100 & 4.114) = $1400.00
UNIVERSAL PARTS
Pair of Recaro reclinable seats(Brand New)(With universal rails) = $800.00
'A' Pillar mount for 52mm gauges (x2)(EC)(Universal) = SOLD
Din Gauge Holder for 3x52mm gauges (Brand New)(Universal) = SOLD
Sony CD player (Like new)= $150.00
Bosch 910 fuel pump (Brand New) = SOLD
CA18DET AFM (GC) = $75.00
CA18DET Stock ECU = $100.00
RB20DET AFM = SOLD
Line Locker Kit (Brand New)(Inbox) = $200.00
Also will trade/swap for:
- Coilovers (GTST)(Height and damper)
- R33 Eye lids
- Apexi Pen style turbo timer
- Boost Controller
https://www.sau.com.au/forums/topic/47676-garagecleanup/
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
