Hello,
Not sure if this is posted in the right section but I have been unable to find out anything about my question anywhere and it may seem silly but does anyone know if a defect notice becomes invalid when they don't fill in the correct information.
Example: wrong vin number, wrong license number and no engine number
It actually states on the form I received that 'where a chassis number used a engine number must be recorded and a section for the engine number under it which was left blank.
It's a new defect on a big registered car which has no problems, the cops right from the start were rude, arrogant and aggressive when I questioned anything they said, and yes I called the nsw police and they said they didn't know and had to call back to ask the ticketing officer if it's valid, not that he can actually give a proper awnser on it as he has a conflict of intrest
https://www.sau.com.au/forums/topic/476782-car-defect-notice-valid/
There's no way you would ask the cop, of course he would say its valid. Its fact, police do make mistakes and issue notices in error so worthwhile to push further and seek legal advice if you believe this is the issue.
In the vin he wrote BCR33 but it's ECR33, they only put down 6 of the 9 numbers for my license as well, I will be seeking legal advice on it but curious if anyone else has had this happen to them, wensday next week I have a solicitors appointment, it's still a pretty big screw up on their part though, my wife called vic police and they actually said if I removed the yellow sticker the new defect wouldn't show up on their systems and wouldn't care less, I didn't have my license on me as our friend was in hospital and we were in a rush but when I told him that he didn't even ask me my name, d.o.b, or address
Edited by FedBpy2018
Certainly don't ask the cop - he will just issue another notice with the correct details. Hope you got a name from the cop who advised you to remove the yellow sticker. Solicitor will clarify legal position for you. If you didn't give him your name and address and he has your licence number wrong I wouldn't think it will be a problem. Especially if you are sure that the defect notice is wrong anyway.
49 minutes ago, 260DET said:
If it becomes a problem for the cops my semi educated guess is that they will apply to amend (correct) the notice. Everything is weighted in favour of the police who make mistakes all the time.
Yeap, and then they will most likely make sure the inspection is, lets say, extremely thorough.
If I was the cop/traffic authority that's what I would do.
Just clear the defect and frame it for posterity.
I had a collection of them in my youth.
Or fight it, but keep uninformed.
  • Like 1
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to moth things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
    • Editting as I hit post to soon, and this will lock out otherwise.
    • Think ill be going hunting for bad earths and might just replace the alternator for shits n gigs as its an LS alternator but only about 5 years old with very minimal use in that 5 years.
