hey all!
Just purchased a 1999 Stagea RS4S and i am wondering what would be good mods that i could do to make it into a really nice to drive street car. Already has a FMIC, exhaust and a boost controller as well as some suspension work. any recommendations on parts to keep her running good or things that could be replaced for longevity?
Thanks in advance, looking forward to being apart of these forums!
cheers from Canada!
https://www.sau.com.au/forums/topic/476792-parts-for-stagea/
Must be a rare beast in Canada! Auto or manual?
A Nistune chip would optimise performance and fuel economy.
You could spend thousands (a couple or ten) to make it go faster but for reliability go through the do it yourself section and the maintenance section to help with replacing all fluids (engine, transmission, brakes) with new stuff (may not have been done in almost 20 years) and I guess particularly in Canada make sure you have fresh antifreeze of the correct specification.
If the coils look like the original ones you could forestall future problems by getting new OEM coils or Splitfires and check and if necessary change the plugs. See if the coil looms look old and cracked as they can be purchased for not too much $$.
And spend a bit of time going through the Stagea section - lots of good stuff there!
    • I would again like too thank Matt for his help in me sourcing the detachable hard top for the little red car, without Matt's assistance in inspecting it and locking it down, I can guarantee it would have sold before I could get up to see it,  and as that was the only available NC hardtop in Australia, I consider myself extremely lucky on multiple levels To say I'm more that happy would be an understatement And, it is 100% water tight, I drove through torrential rain coming back south, and by torrential, they type of rain that doing 40kph in a 110kph zone was a real thing, and even then, the standing water on the Hwy was deep enough to throw waves I'm also more than happy that the huge "BEASTS" that Matt calls dogs didn't eat me for lunch, I'm sure the sniffs and licks were more to "taste test" me, over being to friendly Now to work out what colour to get it painted, panel match, or gloss black........first world problems are real
    • Actually I might have figured out. Looks like there is a tab according to google images but it's hidden. Silly me.
    • No clips on this one like the other connector. Only that red tab that I can push slightly up.
    • For any loom connector that has an obvious release that resists pushing far enough to unclip, just spray some silicone lube into it. You might also benefit from using a bent screwdriver or small pick to push in the right place at the right angle.
    • Hey all, I went to try and fix my indicator not canceling, but I couldn't remove the clockspring cable under the column so I could twist that green thin. Anyone know how to remove this cable? I see this red tab but didn't have any luck. I was thinking of unscrewing it but wasn't sure if it would cause issues. I did notice for my indicator stalk, 2 out of 3 cables were plugged in but the last cable wouldn't fit in the stalk. I'm getting it's for fog lights. It was like this when I originally pulled it off.
