hey guys...i finally found a sik R33 GTS-T only problem is some d!ck talked my dad into thinking the car is way to powerful for a P plater...(probably rite) anyway my dad said it's all cool for me to buy it..BUT i have to make the turbo not work AT ALL... :S anyway i was just wondering how do i do this....and how much will it cost...and will i be able to just turn the tubo back on lata. what other things will this effect...eg fuel going into the engine etc.. thanks for ur help guys. need quick reply though
https://www.sau.com.au/forums/topic/47683-help-turbo-question/
  • Replies 54
hmmm, i don't know a lot bout engines, but you may be able to turn the boost down quite low? Can also install more restrictive air intakes. These would reduce the power BUT, it doesn't really matter in regards to Power to Weight/Ratio rule as the rule goes off "FACTORY FIGURES" - Meaning no matter what you do, a turbo R33 coupe is always going to be over the power to weight. But you could get a non-turbo R33 and THEN turbo that, and you'd be fine, because the factory figures for a non-turbo are ok for power to weight. Bit silly isn't it? :(
cheers.
if u get a machanic certificate saying it's been de-tuned then they accept that. but i want to be able to turn the turbo back on afta about a year so i don't wanna buy a non turbo and then sell then buy another GTS-T. my dad just doesn't want me to get any boost. thinks i'll kick the back out on a corner to easily
buying a non turbo then changing it to a turbo is too expensive. It will also cost you money if you buy a gts-t and then spend the time f**king around with it detuning it. The best solution would probably be
a)just to buy a shitbox for this year, and then buy a gts-t next year.
b)If you already have a car, dont buy anything. just hold off your purchase until your allowed to be able to run full boost.
Should of done that, waited myself, but didnt, cost me upwords of 8G's to convert to turbo with minor mods.
As far as i know just turn boost to 0 with a boost controller and the turbo will never spool up.
If thats any help
1) You cant turn off a turbo
2) You cant de-tune it and get it "certified" by vic-rods standards
Do yourself a favour, guy a shitbox and drive it around for 2-3 years first.
If you smash it it dont matter, insurance is cheap and affordable too
There is a good place in Thomastown on Mahoneys rd - 308 i think the number was...
Me and dj_lethal just brought some daily driver bombs and cost us like $1700 each and there are in A1 condition mechanically.
Get a bomb
r31 nismoid is right. it would be a lot easier and cheaper just to buy a shitbox until you are allowed to get a gts-t and be able to run decent boost levels. i personally dont see a point in buying a r33 gtst then spending the time and money buggerising round with it to basically disable the turbo so to speak. just my opinion anyway
i thought it was real easy to stop the turbo all u do is open the wastegate yeah and remove the actuator and that's it...then i can just put it bak on after bout a year of driving by myself..it's just so i don't crash it that easily...only 3rd party insurance :S i don't wanna waste time gettin another car then selling and then gettin a GTS-T
aahahahaa
1. Turbo can only run Factory Boost Lvl which is 0.4bar, even with a ebc it can not be turn down lower than that (ps i have try)
2. P's + turbo = bad news,
Its got nothing to do with u being young or anything like that trust me, i own an r33 gts-t and im only 17, but i can tell u all the money i make goes into the car or goes towards saving for something. Things like clutch, shocks, tyres can go at any time and cost alot to replace.
Also fuel and insurance isnt cheap, yeah go 3rd party, i did but when u hit someone see how long it takes u to just get enough money to fix your car or even pay the excess (mine is around $1000)
Guest Slide
buy a dual stage boost controller set 1st setting to really low for when your dad knows
then set the 2nd stage to what ever you want.
what dad doesnt know wont hurt him.
just dont boost it into a Gutter,tree,house,car etc as this would give it away.
turbod cars are meant to utilise the extra air imput and extraction from the turbo i have turned mine down for a day to see what happened to about 2psi and it spikes to 7psi anyway.
just retard the effects of the turbo by turning the angle sensor you will feel more engine and less turbo but it will still be there wouldnt recommend for long time though and should be properly detuned by specialist Skyline Doctor
This thread would be the WORST I have ever seen for people who know fu(k all giving technical advice.
Firstly. A Boost controller can not turn your boost down lower than the pressure set by the spring in the wastegate actuator. In the case of a R33, 5 PSI.
Secondly. Even with the wastegate wired open the turbo will eventually spool up to some extent. doubt it would develop much boost until near redline.
Thirdly. Take the advice of people who have been there before... BUY A SH!TBOX for a year.
If it is your first car you WILL crash it or damage it in some other way trust me. If you want to stay with a sporty import Nissan, get a Silvia Q (non turbo). They are cheap as dirt for what they are.
Not that you will probably listen. I know I wouldn't have when I was your age. :-)
Guest Slide
1: what i posted was a suggestion not technical advise
2:I were questioning a post by ADZO about the wastegate
here is his thought
disconnect the waistgate actuator then wire the gate open or pull hose off boost guage
here is my question
wouldnt disconnecting the wastegate actuator confuse the computer into beleiving it is runin lotsa boost or no boost?
if you put some thought into my post it says!
3: it is not me wanting to buy 1
i already have 1
consentrate or that cholesterol will catch upto you really fast
4 just because you older it doesnt mean you know more it just means you have made more mistakes to learn from.
Why be a bully PTR33 just trying to help
    • Absolute Legend 🍻 After fighting with the scanned ones for the last 10 years this is a God send
    • ATTAKD 356mm Brake Kit for R34 GTT or R33 GTST. Same brake kit as per here from JJ: https://justjap.com/products/attkd-brake-kit-nissan-skyline-r34-99-02?currency=AUD Can confirm these will bolt directly to a R33 GTST with 12mm bolts OR to a R34 GTT (which is what I had) with the supplied bolts and the collets for the 14mm bolt holes in the R34, which are included. Also included is a set of rotors and hats, as well as 2x brake pad sets. 1) DBA XP (street, hills) 2) Forza FR6 (track) These are radial mounted and bolt directly to R33/R34. You will need extended brake lines to avoid them being full stretch on lock - this is common for all BBK's with the bolt point being in the center. In my case I welded another stud about 25mm lower than the OEM one and retained stock lines and fittings. You'll want a BM57 BMC to get the most out of these. I speak from experience. $1800 (neg for SAU people), located SE Suburbs Melbourne.
    • Set of R33 GTST Calipers, Rotors and Pads. Calipers just taken off my car, rebuilt about ~30,000km ago. Rotors have done about ~20,000km total since new. Pads have plenty of meat. One set is DBA XP (road, hills) and the other set is Forza FR6 (track) Still working perfectly, not rusted, or seized or whatever the hell that greets used brakes. All clips, bolts, retainers, slide pins etc included. Also have OEM handbrake shoes I can throw in there if you're doing a conversion. $650 for the lot, SE Suburbs Melboune/VIC
    • I feel I have covid right now. I spent the time between Dec 21 and Jan 31 pretty much working 16 hour days on the car after it got back from paint. It turns out you generate a long list of "things to do" while the car is off the road but functional. After going to visit my mate for a "Couple of hour job" doing the brakes, 3 full days later I got home There was more on the list, (it got added to while sleeping on couches) but as everything on the list got enthusiastically crossed out as it happened, I've actually forgotten what they were. From memory there were bushes that had to be pressed in and out, washer jets to fit, etc. Some Gregging highlights: 1) The panel shop covered up my washer jets and painted over it. Good job, I think. We had to drill the new bonnet to fit new ones, which was understandably extremely scary. 2) My handbrake on the RHS is f**ked. After never adjusting it forever and learning on the fly, this one is still on my to-do list. It tightens when you pull the lever, but at about 10% of the tension that the passenger side does. Thoughts on what causes this would be great. 3) Pouring an entire liter of brake fluid over the reservoir because I forgot how to use my pressure bleeder. DON'T PUT FLUID IN THE RESERVOIR. IT WORKS BY USING PRESSURIZED AIR NOT PRESSURIZED FLUID.   471907729_9242915229093447_2708910336906717367_n.mp4  I can confirm the vents work great though. 4) Some of the bodykit fixings were f**king awful. I'm talking screwed in with what was at most a 2mm screw, and could flap the kit around by hand. Too many others to mention. They came in, went out of my brain forced by other stupid tiny things that came up and "While the car is on the damn hoist we can fix them" which was a mission in and of itself, because the car has skirts and is thus a pain to put on hoists. Because we had to buff the windscreen to get rid of the overspray, I also had to very gently wash the car. The "Run 3 wires" task was to re-attempt another gregging thing which was: The LS1 ECU in Australia does not have oil pressure wiring because the Commodores do not have a 'real' oil pressure switch The Corvettes in the USA do have oil pressure wiring because Corvettes have a real oil pressure switch. The ECU is the same physical ECU. So what I could do is pull the ECU apart, run 3 more pins and run it to the OEM oil pressure ECU, and the ECU should do this. What actually happened is that Greg did this with some not-so-proper-wiring/connectors to the ECU pins which 'might?' be okay put the car back together, and then the fuel pump wouldn't prime. So you can imagine I immediately undid all this work, put the ECU back into it's original configuration, thought I'd do some more research about what connectors the LS1 Ecu actually uses... and try again later. Except still no fuel pump prime. After a lot of sadness and checking/double checking it turns out it was the relay in the boot that controls the fuel pump. All I did was switch the trigger wires and it worked fine. I looked at the relay and it was covered in bog dust and was unknown years old. It's since been replaced and working fine. After I got the actual connectors, and the wires were ran I gathered my strength and repinned the ECU and Voila! I apologize for these MMS  472164532_8829400773820369_5410969472548349643_n.mp4  And even via ODB2 on the headunit, woo. Now Torque Pro can raise hell on track if it gets too low. It has a wonderful EMERGENCY_DISTRESS_SINGAL style warning if it goes below a certain threshhold. 472585876_9345134268844369_146554337148747327_n.mp4 TLDR: Car great. HFM kit works. So much cleaning. Buy my old stuff. Thanks.
    • That's a hell of a question right there and so broad that you could get 100 different answers and have them all be correct.  To avoid me typing up a 2000 word thesis that doesn't answer your question, do you have specific things you are unsure of? Does the car currently handle in a way that you don't like? Or is it closer to, you think the car drives fine currently. But you'd like it to be better, but you don't know what that 'better' is or what that 'better' feels like?
