Hey guys,
Going to spend some bigboi money on a new ECU and will have these available.
1) R34 Nistune ECU with Flex fuel
Have had this in the car running for 2 years. Tuned with 14PSI, front mount ,z32, and 1000cc injectors. Can return to factory if need be.
Has flex loom added to it so all ready for flex!
$475
2) Z32 AFM - Genuine unit. Few years old (Been on two of my cars now in the last 3 years) in good condition! Works very well but no longer needed.
$125
3) Greddy Profec B Spec II Electronic Boost Controller
Works very well. JDM AF. Comes with unit, wiring, boost solenoid etc
$300
4) R35/GTR AFM
Slot style AFM, No housing (Buy weld in bung from Nistune website or ebay) works nicely but we tried a z32 to chase issues (turned out to be a boost leak) and never put it back in.
$100
Can supply pics if need be
Pickup Melb Eastern Suburbs or post
Edited by Pr0x1mity
  • Like 1
    • Gotcha, I mean that is at least good to hear. Are there signs, or troubleshooting tips to make sure the transmission is operating properly?
    • Well thats probably not gonna happen right away. LOL
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
