Hi guys, hope I’m not out of place by my first post on here being asking for help but I live pretty rural and don’t have a whole lot of rb enthusiasts to ask and google seems like a rabbit hole on the topic,
with that being said, here goes
s1 r33 GTST started running rough and blowing smoke, did all the normal checks, ended up doing compression test and found cyl 3 and 4 at 65psi
pulled motor out, tore down and found broken ringlands and deep grooves on bores
as I said I’m rural and machine work is not an option......... BUT..... a mate offered me a low km RB25DE.
so what my question is, if I use the det cold and hot sides on the de block and head, will it be safe??
plan on running factory boost (7psi I think)
yes I know about the higher compression and lack of oil squirters under pistons, having to swap oil and water lines for turbo. I just want to know if this will work, as the screen name suggests it’s the missus car and she doesn’t flog it, I just need to get it back on the road for now until I can get any help or info appreciated
https://www.sau.com.au/forums/topic/476848-rb25det-to-rb25det-help/
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
