hey guys...i finally found a sik R33 GTS-T only problem is some d!ck talked my dad into thinking the car is way to powerful for a P plater...(probably rite) anyway my dad said it's all cool for me to buy it..BUT i have to make the turbo not work AT ALL... :S anyway i was just wondering how do i do this....and how much will it cost...and will i be able to just turn the tubo back on lata. what other things will this effect...eg fuel going into the engine etc.. thanks for ur help guys. need quick reply though
https://www.sau.com.au/forums/topic/47685-help-turbo-question/
nah coz i wanna change it back afta like a year or something so i don't wanna have to sell the car and buy another..sticky tape where. and will the car be putting to much fuel in the engine if the turbo isn't working...can i control this..thanks for the help
so stopping the turbo is really easy...that just means i wont get any boost yeah... now wat aobut the fuel? will the car be putting heaps of fuel in. and will this be all i have to do to stop getting any boost
Disconnect the wastegate actuator from the wastegate on the turbo.
All you need is around 2mins and a really small flat head screw driver.
Flick off the surclip and pull the actuator rod off the wastegate. If you are leaving it like that then wire the wastegate fully open so it doesn't flap around.
Best part is once you get around the corner you can put it back on again in the same amount of time. :(
But yer.. I'd prefer sticking a stick in the turbo to stop it working. :(
The AFM measures the amount of air entering the engine and puts the required amount of fuel in so it will drive like an NA and get similiar fuel consumption.
thanks guys...my dad mite get a bit sus but i'll see wat he says bout it lol. i guess it's for my own good. i mean who thinks that a P plater on their first year with a turbo is a bit much...plus i will only have 3rd party so i can't afford to crash lol. mite jsut do that for the first year or so then use the turbo
Not having a turbo isn't going to stop you hitting some thing.
When I was younger I found it wasn't the acceleration that got me in trouble it was the inability to judge corners and how quick to go through then.
Wet roads and reading the road surface texture is also where I used to come unstuck.
You learn the hard way though :(
There seems to be a trend amongst my friends and now that I am seeing amongst my sisters friends that the blokes with the quicker cars tend not to write them off and drive more sensible only giving it stick out of corners.
The blokes with the smaller buzz boxes go flat stick in to the corners and hit gutters, tree's and write off their cars.
Every one dings their first car. :(
seriously mate, dont get a skyline if ur just getting ur P's and only 3rd party. I guarentee you will crash it sooner or later and i dont want to see another written off skyline. I admit i did stupid things the first year i had my licence but i only owned a shitbox 3k car.
If u really want a import get a non turbo silvia, u can get them for about 5k and they r cheap to fix and better then any aussie car for 5k. Tell your dad to take u to a driving course too.
yeah he's definatly taking me through driving courses n stuff...i'm obsessed with the skyline and have worked hard as for this thing...i know i'm saying this now and it's probably bullshit but i'm gonna be respecting it so...i seem to learn every lesson the hard way lol
nah i need his help for some things with it...like just said he wudn't help me buy it...eg not give me the 2,000 he was putting into it for me...plus there are 2 other cars at my address and being in Vic i need to move them to another property we own so it's legal for me to drive the thing on P's. so he said he'd help with that aswell...i'm lucky we own another house and can register them under that address so i can apply for a high powered vechile thing. that and the money he's giving me are the reason...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
