Ideal Power for Track Car
23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi Guys,
At the moment I'm starting to think about the engine build which  will eventually go into my R32. I am considering doing an rb26/30 build (want the car to feel responsive and not be a lag monster) but just wondering what you think would be a usable amount of power will be for a dedicated track car which will not be overkill
Regards,
Dylan
Well, there's also the question of "What category do you want to win?"
As it stands, the question makes no sense.  You did not specify "just a plaything".  Nor budget, nor prep level of rest of car, as per JGTC's point above.
As such, my vote is the max option on your list.
Edited by GTSBoy
nor mention of existing seat time/experience or handling/brake/grip level
  • Like 2
All of the powers, all of them, just wound back a bit so it doesn't break stuff getting it on of off the trailer.
Or 10% lower than the weakest link
Stolen picture of possible weakest link
KW seem great until things explode and you get passed by a MX5 with 95kw cause that dude has done 180 reliable track days and has seat time.
If you're building a track car, the engine should be the last thing you touch to modify at all, other than cooling ?
  • Like 3
To put it in perspective, I was reading up about road course stuff and someone put a stat out there, in an average 20 minute track session, you're doing the equivalent of 75 drag passes on your car in 20 minutes.
When people say "I've had 400kw for years and haven't had a problem" they are not doing say 375 drag passes in one day.
    • Yeah the issue here is that we have a lot of topics, unless we matched on the exact word & phrase we'd get a million topics and the one you want will not likely be in the top 20 or so.
    • Yeah great idea, I have already added R32 Wiring Diagram but we can add as many as we want. 100% ! This has been something I've wanted to do for a while. I thought we could have a way for people to 'suggest' a link be added to the library when they come across something good.  We could kick this along by allowing members (maybe a subset) to tag threads they find to allow us to more easily find/locate/use good content, ie a tag 'for-library' which can then be added to the library and maybe have the tags reviewed and updated to better match the content. This would make it easier then to find the content when not using the library. We can also create pages that have lists of content with specific tags. That would allow us to add a tag and then have it automatically added to a page. We could have a page just for the 'for-library' content that we could then moderate and put wherever.  This excites me, the lack of structure with the amount of content is a little overwhelming.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
