Ideal Power for Track Car
23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi Guys,
At the moment I'm starting to think about the engine build which  will eventually go into my R32. I am considering doing an rb26/30 build (want the car to feel responsive and not be a lag monster) but just wondering what you think would be a usable amount of power will be for a dedicated track car which will not be overkill
Regards,
Dylan
Well, there's also the question of "What category do you want to win?"
As it stands, the question makes no sense.  You did not specify "just a plaything".  Nor budget, nor prep level of rest of car, as per JGTC's point above.
As such, my vote is the max option on your list.
Edited by GTSBoy
nor mention of existing seat time/experience or handling/brake/grip level
  • Like 2
All of the powers, all of them, just wound back a bit so it doesn't break stuff getting it on of off the trailer.
Or 10% lower than the weakest link
Stolen picture of possible weakest link
KW seem great until things explode and you get passed by a MX5 with 95kw cause that dude has done 180 reliable track days and has seat time.
If you're building a track car, the engine should be the last thing you touch to modify at all, other than cooling ?
  • Like 3
To put it in perspective, I was reading up about road course stuff and someone put a stat out there, in an average 20 minute track session, you're doing the equivalent of 75 drag passes on your car in 20 minutes.
When people say "I've had 400kw for years and haven't had a problem" they are not doing say 375 drag passes in one day.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
