So i did a spark plug change so i had to take my top intake off, so i accidentally swapped 2 vacuum hoses around and i noticed because the car had no power, now i changed them back and now the car feels like it has no top end power anymore. I mixed up hose 10 and hose 3 in the picture
image.png.3f50c01f754de429cc9955c3e35b99
https://www.sau.com.au/forums/topic/476877-variable-air-intake-problems/
Well, if it worked before, and you're sure that you have it back together correctly, then the options are;
  1. You also messed something else up when you put it back together, which is difficult for us to see from here, or
  2. Perhaps having the hoses the wrong way around has caused the variable manifold butterfly to jam (from being driven in the wrong direction perhaps).  Can you try to apply vacuum to the hose that should have vacuum and see if what is supposed to be moving is actually moving?
so i can visually see it working with the actuator, it ticks and flicks on and off. can someone explain how it all works.
does it activate then deactivate when you get into the higher rpm?
because i have the low down power but not the high end power anymore
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
