Hey Boys,
I've just started installing my car audio gear that has been lying around in my room from my previous car (charade w00t), Threw in the alpine deck with out a hitch and cranks fine but just for one thing, the stocky speakers in the door are blown so i'll have to get new ones...
Anyone know if they are a 6" or 5 1/2"?
Im going to replace the rear speakers aswell, i have an mtx amp which i will throw in and a 12" sub but i want to go for a pair....
Another thing im worried about is the amount of boot rattle the pair of 12"s will generate...might have to get padding or something..
https://www.sau.com.au/forums/topic/47689-r32-gtst-install/
I was in the same pos...
The speakers in my doors were ****ed as well.... There Oval shit things.... I put a set of splits 6 1/2". Take out the existing pods in ther doors and put in some MDF Spacers. Mount the speaker to that, and it will fit straigh behind the door.
Ive got 4 12" subs to put in the back, Ive only put in 2 for now because ill have to go custom to fit ther other 2.. Yes it rattles, but i have a full fibreglass bodykit.. and thats the only thing that rattles... So you should be ok with them. The boot lid or quater pannels dont rattle at all.
Hope that helps. :)
https://www.sau.com.au/forums/topic/47689-r32-gtst-install/#findComment-962768
Std fronts are 6x4's. Make some pods and put in 6" components.
I'd leave the rear speakers out of the parcel shelf to allow the subs to port into the car. Better sound, and reduction in rattling.
You can place rear speakers (if you have a coupe), in behind the side panels in the rear, ie the vertical piece of fabric above where your arm rests if you are in the back.
I made some pods for the void space behind the panel, removed the carpet, cut out a 6" hole to let the sound out, put a 6" speaker grill in there from Jaycar, and placed the carpet over the top. You would never know they were there, but you can hear them loud and clear.
https://www.sau.com.au/forums/topic/47689-r32-gtst-install/#findComment-973687
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
