Viscous Fan Clutch rattle & play
My VQ25 has a bad rattle on the fan, and I’ve found it’s coming from the viscous hub/clutch bearing, and found there’s a pretty bad amount of play. The pulley that the belt drives appears fine and solid.
I’m yet to find a local (Christchurch NZ) used part, and Amazon obviously has them for US120 but shipping is outrageous. OEM is ex Japan and $600+.
seems there are no aftermarket parts for this except for the elgrand part from Dayco, but the part number doesn’t match  (and it’s a VQ35) so unsure if that’s compatible.
anyone know if you can pull/press whatever bearing the spindle is on and replace? I haven’t removed yet as I’m using the vehicle so hard for me to inspect myself.
also need to check if the viscous clutch needs checking. Previously I’d had a persistent belt squeal that I couldn’t eliminate and a presumed it was due to excess dust get in there (no underguards currently), but now it occurs to me maybe the clutch going bad might cause a squeal.
any thoughts, parts sources, dodgy fix advice welcome.
cheers
Get one from a wrecker that doesn't have a bad amount of play. e.g. $27 from Pick a Part
Or email Nissan wreckers country wide - fan plus freight should be less than $100
If you cant get one in nz , are you able to switch to an electric fan.(thermos)
Heaps of them floating around.
Seems to be a pretty common mod.
Fans
Sensor/control trigger
Relay
Wire
It'll likely be the bracket itself. Not expensive. Part number should be 21046-4P100. $80USD from PartSouq (highly recommended, quick shipping from Dubai).
If it is the coupler, that's not too bad from PartSouq. ~$50 in shipping to Australia. NZ shouldn't be much different.
Edited by Akshunhiro
Thanks all for the ideas. Hadn’t heard of partsouq. I’d written off pickapart as they never have Stageas but looking again I’ve found two V35 Skylines that should produce what I need.
Electric fan is a good alternative too.
To clarify the source of the problem, it’s not the bracket or the pulley (or the pump). The coupling assembly (highlighted in the pic) has the fan bolted onto it and does itself have a spindle in the back with a bearing where the viscous magic happens. It’s here there is play and rattle when running.
Not being able to remove and inspect it’s hard to figure out what’s serviceable. I was hoping and would have preferred to service the unit by pulling a bearing and replacing or something along those lines. Nevermind.
Judging by the parts diagram, the water pump is not behind this part but is further over and lower, set into the block with dual orings. Must be a different engine?
33 minutes ago, Akshunhiro said:
Your water pump is inboard and driven off the timing chain. Usually last quite a while. I'd avoid switching to electric thermo's. Clutch is more reliable.
^^^what he said. People changing to electric thermo fans often come a cropper.
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
