As the title says iv been in the market for a manual r34 gtt coupe for a few months now. Watching how the market is going im seriously starting to consider buying an auto r34 gtt and then just paying for the conversion (and mechanic labout cost)
The price range between a manual and an auto is insane. Iv been tracking a fairly clean r34 GTT 2 door for a little bit around 14k, however if i wanted to buy a manual version of the car i would be looking at something around 19-20k
Is that big of a price range practical or should i just buy a full conversion kit for around 1800 and pay a mecahnic to swap it for me?
The usual answer is "don't take it on unless you are able to do it yourself". Perhaps that's less so for gearbox conversions than turbo engine swaps, but it's been the usual advice.
However, where there are availability issues and the price difference is that wide, sure it's practical. I did it to my R32 many many many years ago.  It's not difficult, just need all the things and enough skills to make the wiring changes, etc.
If you can do it yourself sure, but you want to be sure of what you're getting in that particularly "Conversion Kit" because $1800 won't get you very far if you're buying all parts brand new.
So yes, but just be careful and mindful that extra costs can pop up, especially if you want to do everything 100%
The conversion cost is about ~1k-1500 for a mechanic to do if for you, so think closer to 3500-4K installed and running.
After that your only issue is the auto steering wheel, but you can always use the buttons to trigger something if you want to get fancy. It is worth doing if you find a really nice auto 34 that is unmolested or has the (other) modifications you are looking at.
There are quite a few conversion threads so go through them and make a list of all the things you will need - many conversion kits do not come with e.g. gear lever (c/w knob and boot) centre console, complete clutch including flywheel, clutch pedal and hydraulics, handbrake, speedo drive,  the list goes on so make sure you write everything down (it will be a long list) and compare it with what you get with the kit. Here they are asking 2,500 to 3,500 for a kit and then you don't always get all that you need. Most importantly make sure its a proper RB25 "big box".
I converted my C34 Stagea because manual ones were/are so rare but if I were you I would keep looking for a manual Skyline.
If you can find a decent auto, i say go for it. Mine was auto and i only coverted to manual 'cos it was time' but i see nothing wrong with going that way - as you say, can be a huge price difference when buying the car in the first place. My conversion kit was 1750aud and i wouldnt have spent anymore than that. By the time you buy a decent new clutch kit, 1piece clutch line, new cylinders etc, better off just getting tailshaft, box and pedals unless you get a cheap full conversion kit.
  • 2 years later...
Do you have links to said parts?  The problem with old forums is there are a bunch a broken links, missing pictures etc.
I recently did a manual swap on my Stagea - here is the guide I used for that and a lot of it is the same for the skyline. Of course any mention of 4WD doesn't relate to you.
I also made a video of the process
  • 4 weeks later...
Question:   I have a R33 GTS-T RB25 automatic in my R34 GT-T.  I also have on the bench... a pull type AWD staega transmission with bad gears, AND a Z32 TT transmission in great shape.    Is it going to even be possible to swap bellhousings from the AWD pull type transmission over to the Z32 and achieve a manual swap?  A spec clutch just came up for grabs, still in package, but I don't know if I can even use it.
Edited by walperstyle
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
