So I am fitting a skyline rear end to an old school capri, I am probably going to opt for an NA gts r33 rear as I need to replace the gears for a 3.5 and will go to an aftermarket LSD so from what I gather the LSD is the only difference. Anyway I want to upgrade to a brembo and it seems 350z maybe a good option. So will the 350z brembos fit on the the r33 rear hub? Is there a difference in the r33 hub between the turbo and NA? Will the bolt straight on? Which discs would I use? Do I need any adapter mounts?
Also, I am looking to put an s15 Silvia front end on this car, from what I gather I need to use an off the shelf adaptor and the 350z disc? I'll be putting all new lines on.
I'll be using a 17" wheel with quite a big offset at least +18.
Thoughts?
https://www.sau.com.au/forums/topic/477008-350z-brembos-upgrade/
