Any one got a rb20det base map file for a wolf v4 plugin , that they would be willing to share with me?
I want to have a play but am new to wolf and am unsure of a couple of the settings to get correct injector/spark order, as the wolf v4 unit may have 25det tune.
I contacted wolf and the unit does both 20/25 without any wire changes.
https://www.sau.com.au/forums/topic/477024-wolfv4-map-rb20det/
As far as i could see in the downloads the maps they have are for 25.
The boss man at wolf said it could be tuned to suite 20 and the injectors/spark pins shouldnt need swapping to correct.
Surely someone with a 20det map or some know how on these old wolf v4 plug in units.
Yuh, that's my point. 3 injector drivers, 3 coil drivers. These are in pairs, so the chances of getting them wrong between near identical engines is really small.  It's firing the opposite cylinders at the same time, every revolution of the engine. Just wire it up. If it fires, you got it right. If it doesn't, there's only 2 more permutations of connections to try.
  • Like 1
Its plugin so wiring it up is prety easy. Lol.
Hmmm wonder if its the same 2 firing and that may be why it works on 20 det...
If i recall its cyl 4 and 6 that are different pins between the 25 and 20 ecu.
Thanks for the info. Ill do some sussing.
Still would be nice to get a gold of a base map for the 20 oposed to the 25.
Use the 25 map and pull out timing on the cruise/vac area to start.
Or download haltech ecu manager and open up a RB20DET map and transpose the data into Wolf.
Also all RBs have the same firing order.
  • Like 1
Isnt there an injetor on a different pin for the 25 compared to the 20?
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
