So was at the auctions and made maybe a bad decision,  picked up an impounded stagea that was/is in poor condition.
It had obviously done a big burn out as the back tires were shredded and sitting on the rims and the back doors and panels covered in black rubber.
When auction was on it was me and another guy and i held on , lets just say it was real cheap.
Tow truck came and getting it off the tray was a mission as its sitting on the rims on low tein coilovers. The exhaust got mangled up by the forklift at the auction as it was bent and squashed...
So once off the tow truck shes got a flat battery, new battery on and she cranks and fires first time, sounded strong and the gears go in tight.
So no thumps (its auto), so changed the shredded wheels and borrowed my r33s wheels and she drives.
Got exhaust redone with 3inch dump, 3 1/2ihnch cat and 3 1/2inch back to fujitsubo muffler with a restrictor, sounds great.
Shes got loud screeching noises when turning the steering wheel and timing belt noise.
So at this point the motor is full of oil leaks and dodgy missing bolts, stupid long intercooler piping, gay dash lights etc so needs alot of work.
So... i dived in and its RB3025 time lol..
Edited by AngryRB
  • Like 1
https://www.sau.com.au/forums/topic/477032-stagea-tlc/
So.. its not registered yet and i already bought an RB30 few months back so no reason not to treat this beast to more cubes.
Its current state was
-stock RB25det, fmic, splitfires,stock turbo but it has aftermarket adjustable suspension arms and tein coilovers
Goals are
- RB3025 with r33 head, stock mani, HKS GT-RS turbo, E85 with nistune, want low -mid range torque as its just for cruising/towing...
https://www.sau.com.au/forums/topic/477032-stagea-tlc/#findComment-7905363
So recently i got to work, pulled motor which is a bitch as always lying on concrete floor and prop shaft bolt tight as hell.
Stripped manifolds off and have measured the RB30 pistons and ring end gap.  Pistons still mint, 1 1/2thou clearance, ring gap on comp ring is at 0.040 which is worn so new rings needed. Bore is still round and hone marks there, its got some scuff marks but not deep so will give a light hone and push on.  Will measure bearings soon.
Painted block silver so i can see any oil leaks in future.
Next week will order more parts and hopefully assemble the motor..☺
No excuse for not having an RB30 people, cubes for the win lol..???☺☺
Edited by AngryRB
  • Like 2
https://www.sau.com.au/forums/topic/477032-stagea-tlc/#findComment-7905365
Presume it was RWD which makes it easier. This would be a good time to stick a manual box in it!?
Just need rings and bearings on the RB30 and its good for 400kw! You will need another ECU for the Nistune. I believe they can handle VCT now?
https://www.sau.com.au/forums/topic/477032-stagea-tlc/#findComment-7905367
Yeah its got no front drive shafts but it has the front diff so was a 4wd at some point.  At this point is cheaper to leave RWD.
I kinda like an auto hey, i have the R33 thats manual making 350kw so for now 250kw thru the auto would be great just to be different and maybe later build the auto with a GT 30/35 and built box but thats distant future..
https://www.sau.com.au/forums/topic/477032-stagea-tlc/#findComment-7905368
  • 3 weeks later...
Slowly progressing, the bore isnt worn much so gave it a hone and because im cheap im putting the RB25 pistons and rings on the RB30 rods rather than buy new rings. I measured all the differences and theres not much compression wise, i think will be around 8.6 roughly.
Broke 2 cam bolts so had to extract them, got the crack in the turbine housing repaired too.
https://www.sau.com.au/forums/topic/477032-stagea-tlc/#findComment-7907598
  • 3 weeks later...
Coming together, have shimmed the pump 3mm and left RB30 restrictors in the block.  RB26 oem head gasket and RB25 oem head bolts.  Vct mod done and bung in old feed.
Handy having your old man thats a retired fitter and turner, i hate having to trust machine shops. I love the process of building these RB3025's, everything just works together so well.  After seeing how well my RB3025 in the r33 works id never be happy with a 25 again..
Should be easier from here..?
Edited by AngryRB
https://www.sau.com.au/forums/topic/477032-stagea-tlc/#findComment-7909087
1 hour ago, KiwiRS4T said:
Interesting to see how it goes. Hope you kept the RB30 pistons - you may want to put them back in.
Will be interesting to see what the comp test shows.. anything over 150 will be a win.
https://www.sau.com.au/forums/topic/477032-stagea-tlc/#findComment-7909189
Put the motor in and started her, theres a few noises that need investigating.
The power steering is one noise, the other im not sure but maybe somthing common to stageas, its like a plate rubbing or in the auto box.
The sound of it cranking is shit compared to my r33, maybe is the starter..
https://www.sau.com.au/forums/topic/477032-stagea-tlc/#findComment-7910520
See in this video, its very noisy like loud screeching, this is without plugs in it.
But suprisingly compression is high.
197, 195, 200, 185, 205, 200
Its high than my 2530neo but that has poncams so drops it a little.
https://www.sau.com.au/forums/topic/477032-stagea-tlc/#findComment-7910530
  • 3 months later...
Found the source of the noise, was a warped flex plate rubbing on the sandwich plate.
Now she starts up and sound fairly decent, timing belt may need adjustment to stop the whirring noise.
Next will be some rego and a s2 cluster and see how it drives.
https://www.sau.com.au/forums/topic/477032-stagea-tlc/#findComment-7918014
Drove her over the weekend and today to work, well theres alot of things to fix to make her sweet but oh well atleast it drives.
I've found that 4th will flare under load so the auto box is dying unfortunately.  But im gonna rock it til she dies and im looking into my options.
On the bright side i freaking love it, 1st and second haul ass in traffic, the stock turbo spools rediculously loud and is very entertaining, many laughs had for sure.
The thing idles so innocently but sounds like a jet, pulls well upto 3.5k then shows over haha but still fun.
https://www.sau.com.au/forums/topic/477032-stagea-tlc/#findComment-7918681
    • The 32 still sits untouched with the broken gearbox. So a little off topic but not worth having a whole new thread. The daily starlet has gotten back on the road after 9 months. Suspected blown HeadGasket at a track day resulted in a bit of scope creep rebuild. The motor got a full tear down, pressure testing, machined for MLS HG, ARP head bolts, new bearings, all new seals etc also noticed some fatigue on the stock exhaust manifold so obviously the answer was a steam pipe manifold and highflow turbo. The exhaust was also looking tired with some rust holes. So I got a slightly over kill system made up consisting of Vibrant resonator and muffler with a highflow cat. The new highflow turbo had a larger inlet so instead of adapting the old intake got a case of the might as wells and had a nicer alloy intake made After the run in was finished i bought a (probably considered retro/vintage) EBC becasue "might as well"
    • Pretty stout result. How much boost? Anything left in it?
    • Just dropped the car off at MX5 Mania to install the intake plenum and give it a little retune  My impatience hates the waiting game
    • SAMSONAS      Just saying      U know and we know U wanna     Just a matter of time....
    • This is kind of what I expected given the use case. I took my liners out for track days too.... It makes me consider just getting a diffuser and not bothering with the arch liners themselves. For the most part I would like to avoid water/mud/jank splashing up from under the car onto the bottom of the engine, lines, wiring, etc etc. (but brake ducts are cool too). Especially given this post on SAU here: Where it's implied you have to cut them because the actual tub is different? Which is pretty damn worrying because that is where the liners rub in a GTR with wider wheels... I definitely won't want to pay $2000 for plastic then cut them up. It also means said wider wheels rub on the tub in a GTT? FML. That said, I have found some evidence someone ran a 295/30/18 without scrubbing these liners. (and by extension.. the tub).
